Special fittings
   / Special fittings #1
Taylortractornut
Elite Member
Iuka Mississippi USA
3550 Fard Backhoe and a 1948 Farmall Cub,
I have a question for yall folks. I dont know the name of the fittings Im looking for or the the Source. Im working on a way to heat domestic water and provide a remote room with the excess hotwater. What I got planned is making a copper coil to go inside the wood heater, like a commercial unit I saw. I got all the stuff to do this, except I dont know what kind of fittings to let my coil inlet and exit pass through the heater wall.
What I plan on doing is making a copper coil that water is run through and into a hotwater heater tank. After that its circulated through the PEX tubing into a smal lcar transmission cooler or other heat exchanger. I saw another home built one that the heater had a set of 3/4 steel pipes welded to the outside of the heater about 8 inches long. The coil was placed into the heater and the lines run out through the pipes in the heater wall. Then the copper lines were braved into place. I want to make mine removable if it doesnt wor I can weld the holes up. Take care Taylor Lambert
   / Special fittings #2
I think what you want are call "liquid feed through fittings".
Look at your local hydraulic supply house.
   / Special fittings
Thans Dave, I told my wife that I knew that someone here could tell me what I was looking for. I couldnt name it even though we use a similar fitting on truck air brake systems.
   / Special fittings #6
Be sure and put some kind of relief valve on this thing. It could blow like dynamite if it gets too hot. A 40 gal water heater full of steam is equal to 7 sticks of dynamite.
   / Special fittings #7
Now that I did see on Myth Busters. Pretty much went through two story house.
Wedge
   / Special fittings
I have a new presure relief already. Actually I have2 of them in the system. The college I use d to go to had an incident in a girls dorm once with a hot water heater. They had hired an imigrant worker to help with plumbing. He saw a leaking fitting and put a pipe plug in it and left it. He didnt know it was leaking for a reason. Later that night it cleaned out the laundry room thankfully no one was in there.
2003 KOBELCO SK235SRLC EXCAVATOR (A54607)
2003 KOBELCO...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
Box Truck Hydraulic Tuck-Away Lift Gate (A52377)
Box Truck...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Informational Lot - Financing (A55218)
Informational Lot...
