spear / Rod damage
   / spear / Rod damage #1
pete928
nuffield 10/60
Hi i have hit some power lines with the bucket ram on my digger and damaged the spear, i have filed off the high spot but now need to fill the hollows which are approx 1mm deep. Has any one have any smart ideas what I could use to do this to avoid replacing the spear?
   / spear / Rod damage #2
Welcome to the forums!!!!
Your question is a little vague.
What type of equipment are you referring too?
Do you mean the tooth on your bucket?
Or is it an auger like on a post hole digger and messed up the lead screw?
I its either of those 1mm isn't much to worry about.
I'm not sure were you are but don't you have to call a locating service before digging? It will relieve a lot of liability and hazard of operating a machine.
tom
   / spear / Rod damage #3
I think he means he got into overhead power lines with the bucket cylinder on a backhoe, and it arced to the chrome rod.. If it's pitted too bad you may have to replace the rod or get it re-chromed. No reliable way to build it up other than spray welding as far as I know.
Sean
Yea Chilly 807 your thoughts are similar to mine but was hopeing for an easy fix, and you are right about the over head lines, 2 lines got the barrel and one hit the rod. "Bugger"
I'm down under in New Zealand
Cheers Pete
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
24FT Enclosed Trailer (A53424)
24FT Enclosed...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
