spear / Rod damage
/ spear / Rod damage #1
pete928
nuffield 10/60
Hi i have hit some power lines with the bucket ram on my digger and damaged the spear, i have filed off the high spot but now need to fill the hollows which are approx 1mm deep. Has any one have any smart ideas what I could use to do this to avoid replacing the spear?
/ spear / Rod damage #2
Welcome to the forums!!!!
Your question is a little vague.
What type of equipment are you referring too?
Do you mean the tooth on your bucket?
Or is it an auger like on a post hole digger and messed up the lead screw?
I its either of those 1mm isn't much to worry about.
I'm not sure were you are but don't you have to call a locating service before digging? It will relieve a lot of liability and hazard of operating a machine.
tom
/ spear / Rod damage #3
I think he means he got into overhead power lines with the bucket cylinder on a backhoe, and it arced to the chrome rod.. If it's pitted too bad you may have to replace the rod or get it re-chromed. No reliable way to build it up other than spray welding as far as I know.
Sean
Yea Chilly 807 your thoughts are similar to mine but was hopeing for an easy fix, and you are right about the over head lines, 2 lines got the barrel and one hit the rod. "Bugger"
I'm down under in New Zealand
Cheers Pete
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
UNUSED KUBOTA M3860 BRUSH GUARD (A62130)
UNUSED KUBOTA...
UNUSED INDUSTRIAS AMERICA F08 HYD TILT LAND LEVELE (A62130)
UNUSED INDUSTRIAS...
New/Unused Solid Backing Plate (A61166)
New/Unused Solid...
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
Vacuum Pump Trailer NR (A61567)
Vacuum Pump...
