Speaking Of Tying Down Tractors
   / Speaking Of Tying Down Tractors #1
nunyabinis
The Outer Limits
Deere
I borrowed my FIL's 6 ton Hudson Brothers equipment trailer to tow my new JD 5105 and equipment home. Before I headed out to pickup the tractor and equipment I did some research on how much the tractor, FEL and other equipment would weigh. I figured around 8,000 lbs so I went with 9,000 just to be sure. The trailer's wheels are pretty far back so I figured there would be way too much weight on the hitch ball for a non-weight distributing hitch so I bought a WDH and installed it. I then ran my 3038e onto the trailer and drove it forward until my tongue weight gauge read 1,000 lbs. I then hooked the trailer to my truck, engaged the WDH chains and measured the height of the trailer tongue from the ground.
When I picked up the 5105 and equipment I drove the tractor onto the trailer until the tongue was the same height that I measured before.
I could not believe how good that trailer pulled with the WDH on it. I could hardly tell the trailer was back there. I'm definitely sold on weight distributing hitches.
   / Speaking Of Tying Down Tractors #2
I'm glad that you were successful in towing your new tractor home. Congratulations in regards to your new tractor.:thumbsup:
   / Speaking Of Tying Down Tractors #3
Where did you find a tongue weight gauge and how much did it cost? I have been doing the balance beam with scale routine and would like to have a real tongue scale.
WDH's are the only way to go. The extra stability is amazing no matter what size tow vehicle you are dealing with.
   / Speaking Of Tying Down Tractors #6
Glad you asked first. That's good info in the link!
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A51248)
UNUSED FUTURE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
