om21braz
Veteran Member
I had a close call of sorts today. Mowing w/ self-propelled push mower (Deere JX75) w/ bagger attached. I was mowing new grass for the first time, super-wet, and had already emptied the bagger several times. The mower has a blade-brake clutch on it, so I simply release the safety bar, blade cuts off, pull the bagger off & empty. Then pull the safety bar back against handle, engage the pto lever and go again. Full again, stop mower, release bar - blade stops cold. Now empty bagger, grass chute full too, put my hand in the chute to push a clod of wet grass thru - not into the blade area, but close. I replaced the bag and much to my surprise the blade engaged itself ! Safety handle is in off postion and pto handle in off position. Thank the Lord my hand was not in there then. Now the blade will not disengage regardless of what I do, turn mower off & restart blade is engaged during start-up, etc. Any ideas before I tear into it ? What I really don't get is it engaging itself - electric pto contacts welded maybe ? Any ideas appreciated while I attempt to find a manual displaced a few years back.
