Rear Finish Mower Speaking Greek about RFM
   / Speaking Greek about RFM #1
Limecuda
S/E Texas
I bought a used Kioti RFM over the weekend. It is a 72" KMR 03-72. It only needed 1 wheel replaced due to a bearing going out. At anyrate I may try to replace all of them and just be done. After calling all of the tractor dealers in my area no one wants to look up the part or give a price on replacement including my Tractor Supply. I believe it is made in Italy by Sicma. Is there a site etc. that has a good price on these?
   / Speaking Greek about RFM #2
Many RFM's seem to use the same type of wheels. If you can't find a Kioti, maybe a Bush Hog, Howse, etc. would fit, and be a lot easier to find.
   / Speaking Greek about RFM #3
Try Agri-Supply. They sell Caroni and it is Italian and many of those parts fit other makes (e.g. Sitrex). Measure your wheels and compare online before ordering.
   / Speaking Greek about RFM #4
Exactly! In fact, find 4 NEW wheels (generics from TSC....or ones from a name brand mower) that fit the existing axle diameter. By installing 4 new ones with a common size, it won't matter all that much if they're a little bigger or smaller than the originals. Most finish mowers have enough adjustment in the deck hieght that you can work around a different sized wheel.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
New Long Forks (A53002)
New Long Forks...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A52472)
2018 WACKER NEUSON...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
