Spark timing on Ford 641
   / Spark timing on Ford 641 #1
MillWeld
Durham NC
Ford 641
I replaced the oil pump and had to remove the distributor in the process. I failed :mad: to mark the position of the distributor rotor relative to the opening and closing of the points so I tried to adjust it by briefly cranking the engine. I was able to get some improvement (firing/coughing) but nothing close to starting. Frankly, I am not sure just what the timing of the opening/closing of the points is to the electrical contact to the spark plug wire is, so I am running this by the best source I know, TBN. I can post pics if needed.
Its a 4 cylinder 641 (1958 model).
Thanks.
FOREST CITY 13' CHOPPER (A52708)
FOREST CITY 13'...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2014 JCB 930 (A53317)
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
