arngsarge
I have a 1954 Ford NAA that sets all year in a shed in the Upper Pennisula of Michigan. I just use it for putting in food plots for deer. Now this area is pretty remote I have no electricity etc so everything is pretty much just get it done. Some years the old Ford can be a bit troublesome to start usually fresh gas and a change of plugs, points and condenser does the job. This year I had no spark. I checked at the points nothing, so I replaced the condenser and points. Once again no spark. I ran a wire from the battery (6volt, positive ground) to the coil and had spark. Lack of time kept me from trying to start it that day and I left the next morning.
I wonder if I would run a wire from the battery to a switch and a wire from the switch to the coil and if I could run it that way without any problem of damaging something else? I could switch it on and off that way. Seems that a wire must be bad somewhere in the system and for now I would just like to get it running. This isn't a parade tractor just a Ford that came from Dearborn to Marquette to live some 60 years ago. Any advice would be welcomed.
