Spark Knock???
/ Spark Knock??? #1
ChevyBlazerBoy
I justed pulled my tractor out for the first time (Craftsman YS4500 LE 22HP Briggs OHV) this spring. Before winter i changed plugs, fuel filter, oil. I seem to be getting quite a bit of spark knock while idling. Sounds like a clacking but I can't hear it while it is higher RPM's. I put the old spark plugs back in and the knock went away but then after driving it around for a bit it started making a little knock while idiling. I am running 93 octane fuel. Any idea's or could it be remnant of fuel stabilizer in the system?
/ Spark Knock??? #2
It's not likely spark knock. What I hear happen a lot on these newer OHV small engines that have hydraulic lifters is the lifters tend to bleed down a little after the engine is shut down during the winter. It can take a good hour or two of running for the lifters to completely fill themselves back up with oil. Until this happens the noise (which is a clacking sound) is especially noticeable at idle, but they will eventually fill back up. Sometimes a little Marvel Mystery Oil added to the crankcase can speed up this process, but not normally worth the bother. If you run it up to full throttle for about 5 minutes and pull and examine a plug and it's tip is brown/tan, you'll know your fuel mixture is OK, and only that along with improper ignition timing could even cause a spark knock, and those are two things that are not even adjustable on small engines anymore.
-Fordlords-
/ Spark Knock???
Great, I will let her run for a while. Sounds exactly what my issue is.
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
Livestock Head Gate (A65579)
Livestock Head...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
Holzfform Chainsaw (A65640)
Holzfform Chainsaw...
NEW HOLLAND 254 - 10' HAY TEDDER (A64277)
NEW HOLLAND 254 -...
