Spare tire
/ Spare tire #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I bought a new trailer about 6 months ago, but it didn't come with a spare. Is there a cheap way to pick up a spare tire for a trailer? Would I be best off getting a spare from the manufactorer? Can you pick up a wheel at a junk yard and add a tire cheaper? I don't know if they are a standard size wheel, such as a Chevy or Ford, Dodge bolt partern or what. It's a 7000lb care hauler made by Trailerman.
/ Spare tire #2
I assume its a 5 lug. The next thing you need to do is figure out the wheel lug nut spacing such as 5 or 4.5". You can get a wheel at a junk yard if you know that plus the rim width and back spacing. Be certain to check all things out. I have seen guys with spares that were the right lug pattern but the back spacing was such it hit the inner fender before the lugs were on. I have also seen wheels where the hub hole was not big enough to allow it to fit on. Lot more too it than it looks.
For example I have a boat that has 5 lug wheels that are 5 on 4.5" spacing and my car haul trailer is 5 on 5" spacing. Pain in the AZZZ!
Chris
/ Spare tire #3
I went to the local trailer place when I needed a spare, he came out and measured the rim and lug spacing. Cost me $90 with the tire. Not sure how much you'd save at junk yard by the time you paint the rim, buy a tire and pay to have it mounted.
/ Spare tire #4
I agree with Mark. By the time you get a used rim, clean and paint it, then get a trailer tire and have it mounted you could just buy a mounted spare wheel and tire from a trailer place. Also, trailer tires are usually marked for trailer use on the sidewall and a regular car tire is not recommended for use on a trailer.
/ Spare tire #5
That's what I did too. Got the same exact rim and tire so I can't even tell which is the spare. Load range E trailer tires and the white steel rim are not that expensive. I just need to figure out a way to mount it to the trailer. I just load it in the pickup for now.
/ Spare tire #7
I agree with what some of the others have stated, just get the tire set up from the dealer and be done with it. I would not be comfortable using a trailer without having a spare available.
/ Spare tire
Well, I didn't think about it at the time. You know, kid with a new toy, not always thinking clearly. The dealers only about 30 miles away, I'll probably order one and go pick it up.
/ Spare tire #9
I ordered a couple of spares for diff. trailers off Ebay. Fair price, new tire and new white spoke wheels that match my trailer wheels. Living in the middle of nowhere shipped to my house means alot to me in saved time and fuel. Terry
/ Spare tire #10
When I bought my trailer I made the deal to include the spare and mount. It wasn't too much as I remember. I think all the trailers came without spares. When you talk to your dealer ask how much to have a mount welded onto the trailer also.
Mine is mounted to the passenger side so to be away from the trafic if on the side of the road; I hope the flat is also.
What I need is a way to lock it.
/ Spare tire #11
I like to use donut spares for trailer tires
Ford 8210 (A60462)
Ford 8210 (A60462)
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
20' Masterbuilt Car Hauler Trailer (A64047)
20' Masterbuilt...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
