3-Point Hitch Spanning Wrench
/ Spanning Wrench #1
Grizz262
Michigan
09 Orange L3400 HST
I looked high and low for a spanning wrench to adjust my Left Arm Leveling Assembly, instead of using the hole at the end of my adjustable wrench. I was tired of the wrench slippting off the end of the metal rod and busting my knuckles from time to time. Sometimes, pain is a great prompter of thinking, so I built one out of a piece of 3/8 re-bar.
It works quite well, and can be reversed for raising or lowering my blade in the dead of winter, expecially when I adjust the angle of the blade to avoid tearing up my gravel driveway.
Attached are a couple photos if you are interested.
/ Spanning Wrench #2
Clever idea that works.:thumbsup:
/ Spanning Wrench #3
What a simple, effective and economical answer to an age old problem!
Even though I have top and tilt cylinders, I did keep and moved the adjustable arm assembly over to the other side so I still have a need for your spanner.
Good job.
/ Spanning Wrench #5
I used a piece of re-bar for mine too, but I drilled a hole in one end that slips over the rods on the adjuster.
Sean
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
211298 (A62131)
211298 (A62131)
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
UNUSED 1RMC HIGH END MASSAGE CHAIR (A64281)
UNUSED 1RMC HIGH...
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
