Spacing pulleys for new engine on Troybilt Horse
   / Spacing pulleys for new engine on Troybilt Horse #1
Skaggydog
Mexifornia
Troybilt Horse
Troy Bilt Horse 4 forward 2 reverse. I removed 7hp Briggs and installed 212cc
Predator, the $99 Harbor Freight special that starts right up. The Briggs had
3/8 X 1 1/2 hex bolt in end of shaft holding reverse on with only a lock washer,
no spacers. I used 5/6 X 1 1/2 in the Predator. When I tightened the bolt the
pulleys slid about 3/8" or 1/2" in front of lining up with bottom pulleys.
Where should I put a spacer and what kind of spacer should it be?
Thank You
Actually I posted the question there first but yours is the only answer that I have received so far. I have everything on the tiller ready to go except for this. I guess I can put some washers between the reverse and the pulleys but that would not keep the pulleys from being able to move forward. Maybe they would stay back against the reverse anyway?
   / Spacing pulleys for new engine on Troybilt Horse #4
I installed the same engine last year, it has done great. I installed the spacer in between engine and the pulley. I used large washers and used a dremel tool to open them up enough to slide over the shaft. I can't remember the thickness but can get it to you later if needed.
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
UNUSED (2) 5200# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 5200#...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A54865)
2008 Sterling...
2013 Infiniti M37 Sedan (A53424)
2013 Infiniti M37...
