Spacing on toothbar
/ Spacing on toothbar #1
plaindave
White Lake, MI
Kubota B7800
Called to order a toothbar the other day and found out that for a 54" toothbar Markham normally puts 5 teeth on it. That's like 1 every 14". Been a few too many years since my Caterpillar days, but that seems too far apart.
What is a typical spacing on the teeth? I'm thinking more like 8-9" would be better, knowing that there is a law of diminishing returns there. More is not always best in this case.
Suggestions?
/ Spacing on toothbar #2
</font><font color="blue" class="small">( Called to order a toothbar the other day and found out that for a 54" toothbar Markham normally puts 5 teeth on it. That's like 1 every 14". Been a few too many years since my Caterpillar days, but that seems too far apart.
Suggestions? )</font>
My New Holland 72" toothbar has seven teeth, or one per foot. The more teeth you have, the less force each tooth will apply to the ground. I'm sure there is a tradeoff and an optimum spacing for each particular task, but I don't know what it is, and I wouldn't worry at all about a 14" spacing. But I'd say for a few more $$$ they would build you one with an extra tooth...
/ Spacing on toothbar #3
My 54" H&H toothbar has six teeth.
LA402 loader on a Kubota B2910...attached is a photo...six teeth seems like a good number, at least visually... /forums/images/graemlins/smile.gif
/ Spacing on toothbar #4
I have the 60" bucket on my Kubota B2710. My toothbar has 7 teeth spaced 9.5" on center.
/ Spacing on toothbar #5
My 48" bucket has five (23 series) teeth, I should have listened to Henro and built it with 6, while it works well I should have gone with one more. The mango sized rocks I am digging out (packed in clay) have a tendancy to slide between the teeth. My next toothbar I build will have a smaller tooth and at least 6 teeth.
/ Spacing on toothbar #6
Call them back. They space them out at 9 or 9 1/2" don't remember which, but they'll tell you. And they will add or subtract to fit your desires for something like $25.00 per tooth. Don't think you'd be disappointed.
/ Spacing on toothbar #7
This is a 48" bar from Carver (actually W.R. Long). It has 6 teeth. I guess that extra tooth must make up for the price diff vs. Markham Welding...
/ Spacing on toothbar #8
My 60" bucket has 9 teeth - (Home made tooth bar)
got the teeth on e-bay, they sent a couple extra teeth by mistake - so I used them all.
Ordered the toothbar today from Markham. Person I spoke to the other day was wrong - normal for a 54" bucket is 6 teeth. Spacing should work out to about 10" OC, which sounds about right.
Current price is $184 plus another $70 shipping to SE Michigan.
/ Spacing on toothbar #10
This is what you'll get.
2022 EZ-GO ELITE...
CARORI 4' FINISH MOWER, 3PT (A64278)
CARORI 4' FINISH...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
