SPACER FOR CHEVY
   / SPACER FOR CHEVY #1
bjess8
Bronze Member
SOUTH CENTERAL ,PA
GRAND L3130
ok I put a leveling kit on my 05 chevy 2500 HD 4wd,just wanted to make it look not so OLD MAN looking and wanted to put alittle bigger tires on it as well, now when I hook up to the trailer and put a fair size load on,it squats a good bit.
So hear is my question...I was looking at some spacer blocks for the rear end just to raise it up alittle bit like 1-2 inches and was wondering if anyone has used them before and wouldlike to know the pros and cons on them.
thanks
   / SPACER FOR CHEVY
I have not done anything to the truck other than the leveling kit..I never gave a thought to air bags I might look into those..is there a better quality air bag or are most of them about the same?thanks for the reply
   / SPACER FOR CHEVY #3
I use removeable leveling kits.
Leveling kit 1 = 27' 5th wheel
Leveling kit 2 = 1-1/2 yards 3/4" road base
Leveling kit 3 = 1 cord oak firewood
IMHO, a leveling kit is for a street truck that is not used. As you found out, you went to use your truck, and now the backend sags relative to stock.
The "old man" look, is the look of a "real truck" :D
For what you describe, you might look at an actual lift kit, that raises the front for some tire clearance, but also keep the back just a little high compared to stock
I have friends who did what you did. They haul horses, so they added air bags. Works for them...
thanks
   / SPACER FOR CHEVY #4
You are really stuck. The truck have a slight rake from the factory for a reason. To make them ride level when they have the load on them. Adding lift blocks in the rear will only get you back to where you started as far as looks but now worse due to higher height and more GM square wheel well look. I would put it back or try a set of non lifting overload springs in the rear end.
Chris
   / SPACER FOR CHEVY #5
By leveling kit, I assume you mean offset torsion bar keys. I don't think there is a simple solution to your issue. You could possibly look into a set of timbrens for the rear to limit the squat in conjunction with turning your torsion bars down a little to give a slight rake while still keeping the lifted look, and finaly add a weight distributing hitch system to limit squat. I have never attempted this, but if I had my heart set on the leveling kit, I would be looking into this or a similar setup.
Personaly, I would remove the keys, crank the bars 1.5 to 2 turns, and slap on some 285's for a beefy look while still leaving a functional empty rake.
   / SPACER FOR CHEVY #6
Thats what all the GM guys do around here. Gives the truck a whole new look with that done and some good aggressive tires like BFG's or Dynapros.
Chris
   / SPACER FOR CHEVY #7
Cranking the stock bars accomplishes the same thing as the leveling keys, albeit with a harsher ride and probably damaged shocks. If you installed a commercial leveling kit, like ReadyLIFT, shock extensions were included to prevent this.
If you want some of the rake back, there's no need to remove the leveling keys, simply turn the bolts the other direction, I think it's CCW. Also keep in mind, if you do any 'cranking', to raise or lower the front suspension, you will need to get a front end alignment.
I'm not sure what the 2500 HD has on the rear suspension, but the 1500 comes stock with 2 inch blocks, hence the 'old man' factory rake. Therefore, you can't just add additional rear blocks, you'd have to replace the stock 2" blocks with 4" blocks. Stacking blocks is a bad idea.
I'd go with overload springs and leave the front end alone. It's the simplest solution to get rid of the 'old man' look when empty and ride level when loaded.
   / SPACER FOR CHEVY
Yes I should have done some research a little better before putting on the leveling kit on the front(which was new keys)but i think I will crank the bolts out some and see if this help..it should...I know it is all preference but I just do not like the look of the truck with the nose so much lower than the back..I do not tow hardly at all maybe once a month or so...I might even look into the air bags..thanks for all the replies..should have done this before I put the ready lift keys in...I do like the look now...just not towing :D I will get it correct just needed some good opinions on what to do...thanks
   / SPACER FOR CHEVY #9
Don't forget the front end alignment. :)
Overload Springs - $359.10
Air Bags - $252.86 - Just the air bags, no onboard compressor
Timbren - $194.71
   / SPACER FOR CHEVY #10
Not exactly true, 1.5 to 2+ turns beyond stock on a HD GM is not enough to snap,dislodge, or otherwise damage the front shocks. Only when somebody gets overzealouse turning the bars up, say 3 or more turns does this begin to become an issue. While turning the bars up does not increase the maximum rate, it only makes you start out closer to it, turning them down more than say 1 turn gets you far enough away from it that you will bottom out on the stops before you hit maximum rate.
UNUSED MOWER KING SSAB72-72" HYD ANGLE BROOM (A51248)
UNUSED MOWER KING...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT IDENTIFIER 42 (A53084)
A1 MIST SPRAYERS...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A51248)
UNUSED RAYSKY...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2021 Bell TC-11A Crawler Carrier Dump (A52384)
2021 Bell TC-11A...
