Tires sourcing 9.5x22 tires or should I foam old tires.
   / sourcing 9.5x22 tires or should I foam old tires. #1
dangerdoc
I have a M5400. Put another pretty good rip in a front tire again. Went down to Hey wheel. They recommended not fixing the tire but after a long discussion, we realized that the tire size is pretty much unavailable and they didn't have a good plan for making me rims that would use a more common tire size.
They are going to put a boot in the tire but I expect this is a temporary fix. The tires are old, about 80% worn and checked. I wouldn't normally consider foaming tires in this condition but I am considering doing so to keep them operational for as long as posible. I mostly mow grass, blade my road and move fire wood. I rarely get off the property with the tractor. The tractor used to live outdoors before I bought it but now lives in a barn.
I'm curious if anyone here has had luck sourcing 9.5x22 tires or experience foaming old tires.
   / sourcing 9.5x22 tires or should I foam old tires. #2
I’d sure be surprised if a Kubota dealer could not get you a set of tires the right size for a Kubota tractor. My local tire dealer was been able to get any size tractor tire I have ever needed but I am sure there are exceptions. Have you checked the Titan tire web site or Goodyear site? Foaming would most likely work but it is a rather expensive option for a tire that is pretty much wore out.
MarkV
   / sourcing 9.5x22 tires or should I foam old tires. #3
Hey Doc I found that Bridgestone makes a tire that size. Just not sure what tread pattern you are running.
MarkV
MarkV
I forgot to mention, after a couple of hours searching the internet, I did find a dealer with the tire but they want $450 EACH!!!. Which to me equals not available.
   / sourcing 9.5x22 tires or should I foam old tires. #5
dangerdoc.
I also have a m5400. In looking around for tires, I think you can move up to the 24" rim, I do not remember the tire size. As long as the rolling diameter is with 1-2% of the old tire, you should be fine.
Also try ebay and craigslist
design
design said:
dangerdoc.
design
I have tried ebay, that is where I found the $450 tires. The dealer will sell them to me for about $400 a pop.
When you say moving to a 24" rim, are you talking about finding new steel rims? I spoke to Hey machinery and they didn't think they could help me with new rims. If you know of a source for 24" rims that will fit, let me know, I am very interested.
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2015 PETERBILT 367 SLEEPER (A52576)
2015 PETERBILT 367...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
