Source for this fan???
   / Source for this fan??? #1
GinNB
NB, Canada, eh?
2x Kubota M108S, M105S, 2x M9000, IH885, IH584, IH484, IH454, F3000, F3610, C50, JX70, Landini 5830, JD4630 sprayer
Has anybody seen a source for a fan that looks like this? This one came loose on the shaft, ovalled the center a bit, and wore out the blades on one side. It's cast and the vanes and center are roughly 1/4" steel. It's belt driven at a speed approaching 10,000rpm, so whatever I replace it with has to be well balanced. Diameter is 12" and it's roughly 3" wide. Shaft size is 1.25".
   / Source for this fan??? #2
Fan? I'd call that an impeller. It probably started out life moving liquid, not air.
//greg//
Good point Greg. I certainly haven't been able to find another "fan" that looks like this.
It is. It's normally run by an 18hp twin cylinder motor (well, a small oil pump is run by the same motor, but it doesn't take much grunt at all). I've tried a 14hp single cyl Honda but it loads it up fairly heavily.
   / Source for this fan??? #6
Google New York Blower. They make large blowers and heavy fabricated steel impellers.
Thx Harry, will do.
It's the fan off of a blueberry burner. I've done a more accurate calculation of the speed and it turns at 9000rpm. Local machine shop sources tell me that it'll be close to $1000 to fabricate one and have it balanced. :(
   / Source for this fan??? #9
I give up! What's a Blueberry Burner?? Sounds like something I might need!:D
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2008 CATERPILLAR D6K LGP PIPE LAYER (A50854)
2008 CATERPILLAR...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
