Source for Pallet Fork Frame Only - I have the Forks
   / Source for Pallet Fork Frame Only - I have the Forks #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
I need a frame and QT plate I can mount my 16" Class II forks onto.
Thought I would build a rame myself but just don't have the time.
   / Source for Pallet Fork Frame Only - I have the Forks #2
Loflin in Denton, N.C. My dad had his made there and it looks great!
Loflin Fabrication
   / Source for Pallet Fork Frame Only - I have the Forks #4
What's QT? Titan attachments carries a United Attachments SSQA frame that's made in the USA... here...
Titan has a 10-15% off deal all the time, and they deliver quickly. Sign up for email notices and they give you a 10% off coupon if I recall correctly.
   / Source for Pallet Fork Frame Only - I have the Forks #5
See if you have a Ritchie Bros. Auction in your area.
I have purchased several fork frames from them for making custom implements. They sell both new and used.
Used Heavy Equipment for Sale | Heavy Equipment Auctions | Ritchie Bros. Auctioneers
An example:
   / Source for Pallet Fork Frame Only - I have the Forks #6
I just built a frame for my forks. The frame is built to mount on my John Deere 4430 tractor FEL. I built it with 4"x1.5" channel on top turned up and another of the same on the bottom turned down, lips 16" apart. The ends are closed with the same channel and the mount is done with two pairs of 4" angle drilled to match the so-called "Quick attach" pins on the tractor. The top lip is notched to lock the forks in place. I made the frame 66" wide because that matched the material I had available. I have not taken any pictures because I do not want anyone (SA ?) to see my welds.:confused3:
   / Source for Pallet Fork Frame Only - I have the Forks #7
Titan, palletforks.com. I just got a hay spear from the & added a pair of 48" forks with a hole in the end. They have several packages for frames, forks & spears, just didn't have the exact package I wanted, so I had to piece tigether.
Amusingly I have the frame & the main spear. The forks & small sub spears arent here yet.
   / Source for Pallet Fork Frame Only - I have the Forks #9
I got forks from a neighbor,, they were sitting in a field. It took about 3 hours to build the frame.
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51243)
2001 HAULMARK...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
UNUSED MOWERKING QUICK ATTACH TRENCHER (A51244)
UNUSED MOWERKING...
550 GAL STAINLESS STEEL VAT (A51244)
550 GAL STAINLESS...
Portable Creep Feeder with Gates (A50515)
Portable Creep...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
