Source for longer Control Lever rod?
   / Source for longer Control Lever rod? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
I have a Prince Wolverine MB directional control valve that I want to have a longer Control Lever. OEM is 5.5" long and I'd prefer 10-12" (I know this will increase travel).
The threads are M8-1.25 (course). Any idea where I can find stiff rod only threaded at the end(s)? Needs to be at least 250mm long.
I can find entirely threaded rod but nothing else. I'm also a little concerned about using low carbon steel and having it bend (reasonable concern?)
Thanks.
   / Source for longer Control Lever rod? #2
Bolt and a coupling nut. Cut off the head of the bolt and then thread that end with a die.
   / Source for longer Control Lever rod? #3
What is OD of existing material?
8mm...
   / Source for longer Control Lever rod? #6
Another option is to just get some rod with the correct OD and heat one end cherry red and beat it flat to the correct thickness.
Then drill it for the pins and thread the other end for the knob.
Exactly how much force you figger you're gonna be applying to actuate the valve ?
Should take all that much ... considering you'll leverage working in your favor ... ;)
John Deere Hayrack (A50515)
John Deere Hayrack...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
2012 VOLVO L90G WHEEL LOADER (A51242)
2012 VOLVO L90G...
John Deere 625F Grain Platform (A50514)
John Deere 625F...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2012 Ford F350 Bucket Truck (A47384)
2012 Ford F350...
