Somewhat Scary Experience
   / Somewhat Scary Experience #1
ptrotter
Sussex, NJ
Kubota B7800
Yesterday I was mowing the lawn with my B7800 and MMM and had a scary experience. I had just turned down a slight hill and removed my foot from the forward HST pedal and instead of stopping, the tractor kept on rolling down hill, maybe even accelerting a little and brakes had less effect than I would have expected. This has never happened before, usually the tractor slows and stops immediately after lifting my foot off the pedal. The only difference this time is that I was in 2WD and I usually use 4WD. I put it back into 4WD and it was back to normal. The hill was not very steep and quite short so it wasn't an issue, just a small scare when the tractor didn't react as usual. Has anyone seen this before, or is it normal in 2WD?
Paul
   / Somewhat Scary Experience #2
This is relatively normal, especially if you have the loader attached and/or the grass is wet. There isn't enough weight on the rear tires to slow you down.
Kevin
   / Somewhat Scary Experience #3
ptrotter,
As kevin said it is normal. I have steep hills to mow and today was out on a flat spot so put my BX in 2WD and forgot to go back to 4WD when I was back on the hill and luckily I was on the downside when I went down and the exact same thing happened to me. I always mow in 4WD because of the hills.
Take care TPS
Thanks for the responses, I feel much better now. I rarely take the tractor out of 4wd so I had very little experience in 2WD.
   / Somewhat Scary Experience #5
My B7800 would do this so I always kept it in 4WD except when going up the road or for that matter down the road.:) If you ever hit wet grass going down hill you will always remember to never do that again.
   / Somewhat Scary Experience #6
So, theoretically speaking, is there any good reason to ever put it in 2WD? I'll be taking delivery soon of my first-ever tractor and was thinking I'd likely always leave it in 4WD.
   / Somewhat Scary Experience #7
That is an excellent question. For many tractor owners, they should
never take it out of 4WD. If you drive on pavement, however, you will
wear out your front tires very quickly driving in 4WD.
I once had a scary moment, when I was a newbie, having put my
tractor in 2WD (I have lots of pavement as well as lots of unpaved hilly
land) and forgetting it was in 2WD. I never forget now!
   / Somewhat Scary Experience #8
ptrotter,
Take care TPS
Why I keep mine in 4x4.
   / Somewhat Scary Experience #9
You'll scuff up the grass a bit more turning in 4WD than you would in 2WD. Probably a little more fuel consumption in 4WD. I live in Illinois where we haven't seen a hill for years, so I don't use 4WD very much unless I'm using the bucket and need the traction.
   / Somewhat Scary Experience #10
I've had the opposite experience...I've found the rear wheels of my Kubota do more damage on turns if I am in 2WD.
I've had the same experience as the thread starter and now always operate in 4WD unless traveling on a road
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
