Something to tear up sod
   / Something to tear up sod #11
I made a dirt bike track in an old pasture. Tough job for sure, very rough to start with. Bush hog, disc, spike diamond harrows and land plane. Quite a few hrs in the seat. Turned out pretty good, son took his Ford Raptor on it. Doesn't shake the eyeballs to do a couple of laps now. In the meantime I also got a three point cultivator, need to try that on another area. The three point disc seemed ro give the best results to start with. Getting out with dirt bikes sure did a job on the remaining grass.
   / Something to tear up sod #12
I would suggest a disc, you can get adjustable height units designed to be pulled by ATV’s or a chisel plow similar to what was shown in the picture on the blue tractor. Not sure if these are available for an ATV without modifying.
   / Something to tear up sod #13
Buy a drag harrow for your ATV. Tractor Supply has then in 4 foot widths. I think they are 4 foot long. You can make it aggressive or flip it over for less aggression. 11-9-13 Dam Smooth and Seeded.jpg11-9-13 Dam Baby Smooth.jpg4-22-13 Drag Harrow Side View.jpg4-22-13 Drag Harrow.jpg
I have a 10 foot wide one and love it. It has two sets of harrows making it 8 or 9 feet long. Great for turning under grass seed an inch or two down. Here is my thread on it... https://www.tractorbynet.com/forums/attachments/277658-amazing-find-drag-harrow.html
hugs, Brandi
I found a you tube video for something I was originally thinking of building, shorter tines would be fine for what I want. I have a few side shaft engines kicking around. At the end of the day this would be cheaper than buying a small disc harrow.
Stephen's homemade tiller - YouTube
Original poster here. I couldn't let it rest and finally got around to building this contraption. I had pretty much everything kicking around the shop except for some pillow block bearings and sprockets. Engine is 8 hp from dead generator. Drum is turning 320 RPM at WOT. I welded 22 6" length of scrap leaf springs on for tines. Engine doesnt bog down at all and tears the **** out of the sod. 20200418_211607.jpg20200417_144838.jpg20200418_183300.jpg
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
1991 International 4900 Box Truck (A55315)
1991 International...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
