Something New With My Ford Ranger
   / Something New With My Ford Ranger #11
That's weird.
A Ford work van down the street did the same thing one summer when a rumble of thunder came.
   / Something New With My Ford Ranger #12
Steve, I had the cruise control buttons (switches) replaced less than a month ago........
That may be a clue. I once repaired a turn signal on a 76 Volare. Soon after, the horn would honk when going around corners. My girlfriend got tired of smiling and waving back to everyone at every corner so she made me fix it. :)
   / Something New With My Ford Ranger #13
Was there an issue some years ago with Ford ?? Ignitions starting fires ?
Not sure of my memory or if true the relevance.:)
The interconnection of electrical components can be quite complicated . For example, an electrical component for the daytime running lights on my truck failed. That also made it impossible for me to shut the motor off.
   / Something New With My Ford Ranger #14
At least you have a working horn. My son, years ago spilled a bottle of water on the dash of my 1994 ford truck and the electrical system has had ghost every since. No working horn for probably 15 years.
mark
Egon, the Ford recall 05S28 is the only one I remember. And that "repair" was simply a piece of wiring harness the service writer installed herself in about 2 minutes. I guess the original recall was in 2005, but I don't think it included the Ranger until later. Anyway, mine was done on August 6, 2007.
   / Something New With My Ford Ranger #16
Yea I think it covered all the ford trucks and maybe minivans. I think it was mostly like exploders which is the ranger platform and family as well as the main culprit of the f150 and maybe the expedition.
Yea it was some wireing issue.
   / Something New With My Ford Ranger #17
Yesterday morning, about 6:30 a.m., I was sitting here reading e-mails, news, and weather on the Internet when a really LOUD AND CONTINOUS horn sounded. To say I was startled would be an understatement. My wife and the dog were still asleep, but they sure got up in a hurry. To make a long story short (well, shorter anyway), I traced the sound to my 2002 Ford Ranger in the garage. Both vehicles had been parked there, with the garage doors shut, for at least 15 hours. My keys and remote control were laying on the dresser in the bedroom. So I got the keys, tried pressing the security button on the remote and that made the lights flash, but didn't change the horn. I pressed it again and the lights quit flashing, but no change in the horn. I'm sure everyone is familiar with the security horn beeps, but this wasn't beeping; it was continuous. So I backed the little truck out of the garage so it would easier to open the hood, but when I backed out, I hit the horn button in the steering wheel a couple of times and the horn stopped; Thank Goodness. I talked to my service advisor at the Ford dealer and he'd never heard of such a thing either. The horn has worked normally ever since. Now the owners manual shows a horn relay fuse "unless equipped with a truck central security module". Mine is so equipped so apparently there is only a breaker in that module, and apparently something in that module caused the horn to engage for unknown reasons. This was something I never heard of, and I didn't ask what it would cost if that security module had to be replaced. But in the meantime, since everything seems normal, I'm keeping the right sized wrench handy in the truck to disconnect the battery if need be.:laughing:
Bird instead of opening the truck, then opening the hood and disconnecting the battery cable wouldn't it be easier and faster to reach in through the grille and pull the wire off the horn? On my 2007 the horn is right there in front of the radiator behind the grille.
   / Something New With My Ford Ranger #18
i wonder how hard it is to get to that switch.
I had an old pontiac that had the horn stick on me. I puleld over and puleld the wire off the horn .. luckilly i wasn't on the road following a motorcycle gang or anything :)
as I recall.. it wasn't too monumental a task to get the cover off the steering wheel and correct something loose at the horn switch.
mind you this was inthe mid 80's and i don't there there were any air bags.. unless they were in t he passanger seat.. um.. or perhaps the back seat occasionally ;)
   / Something New With My Ford Ranger #19
i'd also have to say that if hitting the horn button stopepd it.. that you will find the issue in that vicinity.
That's a good possibility, but hitting the horn button could have sent voltage or ground to the sticking relay/controller thereby cycling it.
   / Something New With My Ford Ranger #20
I had the same thing occur on my Honda CRV. I couldn't just pull the fuse for the horn because it is the same for the Brakes and vehicle would not start. It happened after driving that day when it was raining. I don't believe it was the alarm. There is a module that contains the relay and cannot be replaced. You have to buy the whole model $600. It stopped aver sitting for a day and hasn't occurred since.
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Unused Delta Crash...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
