Something interesting I found..
/ Something interesting I found.. #1
Midniteoyl
Super Member
N. W. Indiana
Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Found this on Craigs and thought it was interesting. Says its homebuilt and works. Anyone seen something like this before?
John Deere grader with extra parts mower
This is a homemade John Deere grader. I purchased it for my dirt driveway but then moved and no longer have a need for it. It looks to have a craftsman engine and i'm guessing transaxle. The transaxle like to slip into 2 gears at once and I've been told that the detent springs are bad. I had an extra 60's John Deere 110 that I was going to swap out the rear section to make it a true JD grader. It will come with it. The parts mower will not come with an engine, rear rims and tires, or the front axle and steering assembly along with the rims and tires.
I have an extra wide rim and possibly tire for it. It does run and drive just fine. I has a motorcycle fuel pump, choke, throttle lever, and key switch to engage the starter. The key switch and starter solenoid were brand new last fall. I don't have a use for it anymore and it's taking up space.
Might be interested in trading. Not interested in daily drivers or "boring" things. Would have to be unique or fun.
/ Something interesting I found.. #2
Didn't waldon (?) up in Michigan make one and post pics here?
