Some Temperature Numbers That Might Be of Interest to You
   / Some Temperature Numbers That Might Be of Interest to You #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
This time of the year the Houston Black Clay is like solid rock. I bought a Hay King Pasture Renovator a few years ago and found that it is THE THING for dealing with it and if you want a fall crop you need to get the ground ready before the rains (Ha!) come.
It works the tractor pretty hard and I don't want my tractor to overheat so I work it till the temp gauge gets half way between center and 3/4 deflection and bring it in for a cool down which also cools down the AC and helps to keep me cool with the sun glaring into the cab.
Yesterday, upon bringing it in, I took my infrared non-contact thermometer and took some numbers before the cool down:
Lower block/oil pan area: 278F (no crankcase oil cooler on this engine)
Radiator reservoir: 248 50-50 mix, don't know pressure cap rating
AC Condenser coils: 174
Trans-Hyd cooler coils: 173
Front axle: 135 All 4wd components encased in separate 2.5 gal trans-hyd fluid sump, not cooled.
Ambient temp in shop: 97 Thermometer was in the shade.
Cab interior: 68 Measured on surface adjacent to a cooling register in the shade.
Not really surprised at the numbers.
I do use Rot. 5w-40 syn. oil
Thought about using window tint to keep the sun rays from working against the AC as the sun did warm the air up to something hotter, like maybe 80. I was comfortable whatever it was. Anybody try that?
I was surprised the front axle was running that cool as it was working too.
Obviously the pressure cap was doing it's job in preventing a boil over. The overflow bottle fluid level was fuller than when cold as expected. I do as OEMs recommend and that is to keep the radiator completely full of coolant.
That's about it.
Mark
   / Some Temperature Numbers That Might Be of Interest to You #2
Neat report :)
If 278F was the oil temperature, I'd want to get that lowered a bit. Adding a simple oil cooler would help. The rest of the numbers are pretty good.
Thankfully you're using a synthetic oil, which resists breakdown until around 300F. Normal oil starts breaking around 250-260F. Oil has to be at least 220F to boil off any water into vapor so that it's taken out of the crankcase. A general ideal would be around 230-240. For every 18F that oil is into it's "breakdown" zone, it's life is cut by 1/2.
Yes, adding tint to reduce the sun load on the cab will make a big difference. I think the sun load is 60-70% of the heat the AC has to deal with. Reducing it will pay major benefits.
   / Some Temperature Numbers That Might Be of Interest to You #3
Agree on both the Houston Black and the Hay King! I use the pasture renovator on my Fairlie Clay. Fairlie is similar to Houston Black; both part of the Blackland Prairie. 10" below average rainfall here, so the cracks in the soil are deep now.
Rain will eventually arrive.
Neat report :)
Thanks. Figured at least somebody would like to have an idea as to where things run when you put them to the test.
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
MAGNUM PRODUCTS LIGHT TOWER (A58214)
MAGNUM PRODUCTS...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
