some insight into confusing model numbers please
/ some insight into confusing model numbers please #21
johns_dmax said:
I'm looking to upgrade to a 60HP 4X4 with loader and a shuttle shift of some type. We're going to purchase 120 acres soon and will need to do general clean up, mowing, possibly haying...
Is there a way to decode the model numbers to try to determine which tractor is a budget level and which is a top end? I've looked online and its hard to tell and the dealers want to sell you what they have on hand.
I've found this out so far:
NH TT series only has a syncro shift in top gears not reverse so its out.
NH 2420 has a nice setup in the 12 spd with its electro-hydraulic shift but its a compact so its out.
Deere 5203 was priced at $21K with loader and shuttle shift but I'm concerned about increased wear in clutch from loader use. Nice overall size and weight.
The Deere dealer offered my $12500 for my TC30 with 7308 loader for trade. Good deal with the $21K price?
Any dealers out there that can shed some light on this subject? I know all manufacturers are going to be chaning up their models to make more sense so maybe I just need to be more patient.
If you are looking at haying...save your money and buy a used AG tractor...JD4020 or if you want something a bit smaller 70HP JD2640
They'll probably last longer than the current stuff...:rolleyes:
/ some insight into confusing model numbers please #22
See, now thats good advice. International 766, ford 7000, massey 185/85 or 283, or a jd that pc mentioned would all be great candidates, run for ever & cost less than 10 grand most of the time. Plus older tractors are cooler. They have the same ability as new tractors only cost less. I do agree that a good used tractor along with new or newer cut with fel would be great if you can afford it. Todd.
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2005 FRAC TANK 500BBL WHEELED (A60736)
2005 FRAC TANK...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
2023 FORD F-150 (A60736)
2023 FORD F-150...
1453 (A57192)
1453 (A57192)
