Some flex shots after installing a lift.
   / Some flex shots after installing a lift. #1
Topkicker
Platinum Member
Eolia, MO
Kubota L2501
I put a Rock Krawler lift on the Wrangler. Got these poser flex shots. I wish I had a taller ramp. I still had plenty of flex left before hitting the bumpstops. I got to get this rig muddy, I'm having trail withdrawal.
   / Some flex shots after installing a lift. #2
Looks good! I like those 4 door Jeeps, wife is hinting around at wanting one for her DD. I built a Samurai rock crawler back in 2000 or so, had 5.13 gears,locked front and rear,4.16 case gears and lottsa flex on 35's miss that one.Wished i never sold it now.
   / Some flex shots after installing a lift. #3
Jeep looks great...How bad was the lift to install?
   / Some flex shots after installing a lift. #4
Your loader can help you test your flex :) . This was my old cherokee with stock suspension and sway bar disconnects.
I've seen this done before. I need some bucket forks! My shots were pretty lame. Everythig is so flat around here. I don't even have a decent ditch! LOL. I wasen't even disconected in these shots. Nice Cherokee BTW.
   / Some flex shots after installing a lift. #6
Here's some one ton articulation.
the tire is three feet off the ground and still had more to go....I was chicken it was going to roll off of the fork lift.
JK's (07 and up) are simple to lift. I had a Teraflex 2.5in. Budget Boost which is just spacers above the factory coil springs (all 4 corners) and extended bump stops w longer shocks. The Rock Krawler lift is a 2.5in lift also (I got closer to 3in). This kit is taller coil springs w adj track bar to recenter your front axle. I can get much more flex w the new kit vs the spacer lift. You can lift a JK alone in about 4 hrs if it's a short arm lift. I'll be adding RK lower control arms next. They offer better clearance and allow you to dial in your castor because the length is adjustable like their track bars. Rock Krawler builds a nice lift and can be upgraded without having to buy another complete kit. http://rockkrawler.com/
Is that a Ford Excursion? I wanted one of these in a bad way back in 02 with a 7.3L Power Stroke.
   / Some flex shots after installing a lift. #9
Yes it is a 2005 Excursion..6"/8" Donahoe Racing lift kit...all springs no lift blocks..has about eight thin leaves in each spring pack, very progressive spring rate.
4:56 gears, ARB air locking differentials front and rear.
It will tow most anything with ease. I feel sorry for my dump trailer when I drag it up some of the terrain at the mountain property.
   / Some flex shots after installing a lift. #10
1987 Ford F800 Fire Truck (A51692)
1987 Ford F800...
METAL FILING CABINET (A53843)
METAL FILING...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
