Some disking pictures from this weekend...
   / Some disking pictures from this weekend... #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
For those who like looking at tractor pics at work like I do. After a couple hours of mowing I switched to the disk. A little 5' lightweight but at $200 used it works for me. I didn't get a shot of or main garden, all topsoil and sand. I really have to work the disk to keep from burying the tractor. This red stuff had a good mix of clay (no rocks or iron ore as we call it) but with some sand to. After a couple passes I could still drop the disk all the way and not spin the wheels. It got down about as deep as the disk would go. The pictures with the more yellowish soil is still is about half and half clay/sand. I had a little trouble in it. It's an old garden that we are trying to clean up. It hasn't been turned in several years. I'll hit them again a couple times before rowing up and planting.
Enjoy the pics!!
Rob
   / Some disking pictures from this weekend... #2
That's some really nice ground! I'm envious that you're discing at this time of the year, and of of the lack of rocks ,of course. As I look out today the ground is covered with ice and it will be several months yet before we can work it. When I do and when I disc you can hear the click, click, click as the disc rolls over the rocks.
NICE PICTURES!
   / Some disking pictures from this weekend... #3
Please don't tell me you leave the deer feeder in the garden after you plant it. Unless you are planting it for the deer.
Sometimes I just get lazy...I'll move it later. :D We try and get garden stuff to grow in the spring, then put in a foot plot later. This is a new spot I cleared about 6 weeks ago. My guess is this year the weeds will be brutle. Might see the corn through the mess.
We'll start planting about Feb 1, hope for no more frost. I'll plant several blocks through March 15. If we get rain we'll have corn in May!! :D
   / Some disking pictures from this weekend... #5
You were lucky to be able to spend some seat time disking. I spent some time moving 9" inches of snow around.
   / Some disking pictures from this weekend... #6
Rob,
Seeing how far ahead you are, I'm feeling like a slacker!!! Is this the initial disking? I ask because I've heard that you are supposed to disk the ground to kill the weeds, then disk again when the weeds come back. Then after that you can grow stuff with minimal weeds. There's no stopping them, but at least it cuts down on how many you have to deal with.
I have allot of dirt to move still, but my goal is to be disking by March and planting peas in April. I honestly don't know if it will happen, but what the heck.
Is this garden for you to grow veggies? It looks like a good hunting spot and location for a deer plot.
Thanks for the pics and keep us updated on when you plant.
Eddie
Hey Eddie,
Probably going to plant the easy stuff, corn, peas, beans. It's not fenced so hopefully the local roaming cows will not find it(remember my first real good year for a garden was last year, took home some corn, peas..next weekend the cows broke in and leveled it..I;m going 6 wire this year!!!!!!)
We just found this place and I worked it for the first time 11/30/2007. Here are some pics.. http://www.tractorbynet.com/forums/kubota-owning-operating/111871-60-minute-food-plot.html
With discing, turning, covering seeds that were on top of the ground I suspect a real mess this year..but we'll see. Coastal is usually not a problem, it'll disk easy, it's the other stuff. My main garden area I have been working for 3 -4 years now, still get goatweed and junk popping up.
since I have small areas and a disk, i might disk 4 times a year. After the garden is done and i see some weeds, grass, I'll disk it. About an hour to run over them all. If I had the time I'd go get my neighbors Ford 4630 and his 3 bottom turning plow. Maybe next trip.
when I did some research on planting coastal Bermuda, there is a way to sort of sprig it in for the fastest results. Special machine or something, I've never seen it done myself. I think you can also do this about anytime to...not sure. Common Bermuda seed I found should not be planted until about June. It needs warmer weather to get going.
You bet I'll post some pics...I like to think posting pics encourages others to post. Any tractor/farm pic is a good pic!!
Rob
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2013 John Deere 35D Mini Excavator (A49461)
2013 John Deere...
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
