Some customizing
   / Some customizing #1
Hinomotoman
Western NC
LS R3039, Hinomoto E2604, Hinomoto N239, Case IH 1140, White Field Boss 31
I found a place for a toolbox. A 50 caliber ammo box is perfect. I used existing bolts in the rear. Placed 1/4" spacers between the rear plate and the box for lid clearance. I also attached my 25 gallon sprayer mounted on a cut down auxillary carrier for a receiver hitch. I welded a 2" tube to the drawbar. I also change the trailer connector from the round pin to the flat pins using the existing harness. Now that everything fits I'll take it back off and paint everything and weld up the holes in the box that I drilled on the wrong side.:eek:
   / Some customizing
I wanted to mount mine with the opening towards the outside but the latch didn't clear the fender. That's how I ended up with the holes in the wrong side.
Eugene
   / Some customizing #5
I built a frame for mine so I could take it off when i need too
   / Some customizing #6
I like you sprayed tank idea.
I did one on my zero turn to make it multi use
   / Some customizing
   / Some customizing #9
I mounted mine in the same place, can't find the thread though :) Yours looks great.
   / Some customizing
Added a canopy and some mirrors.
Eugene
2016 BOBCAT T590 SKID STEER (A51242)
2016 BOBCAT T590...
Farm Star 4' Off Set Disk (A50515)
Farm Star 4' Off...
Case 580 Backhoe Loader (A50514)
Case 580 Backhoe...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
