Some constructive criticism, please
   / Some constructive criticism, please #1
johnday
monroe michigan, barton city soon
NH TC 35 had, now a TC35DA LS25 lawnmower
Anybody have any suggestions on the way I've got this tied down? I think I know what I'm doing, but maybe someone else has a better way. I don't need a trip like Dargo ya know. /forums/images/graemlins/grin.gif
#2 I welded these Drings on the other day.
#3 My rear chains looped around the axle.
#4 Front chains with ratchet binder, looped around front axle and thru Drings on front of trailer.
#5 Ready to go upnorth and kill some trees. Leaving tommorow afternoon. First real job for this TC. Thanks guys, fire away at me. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Some constructive criticism, please #6
Hey..
Wow thats confusing!
All you need to do, is tie down each corner of the tractor (axles) to the corners of the trailer. Id put the auger in the bucket and curl it down. I wouldnt tie down the boxblade since its wedged between the tractor and the bucket.
RSC around here just runs a chain through one side to the other going through the tractor. They just use two binders, one for the front and one for the backl.
   / Some constructive criticism, please #7
I don't know that laws in your state but in NY we are required to bind opposite corners with a ratachet binder and at least 1/4" GR 70 chain.
PS: Like the right front corner of the tractor to the left front corner of the trailer.
   / Some constructive criticism, please #8
John,
I don't have any experience with this subject, so I will just throw this out as a thought...
In my mind the tractor should be tied town with four chains, and then the implements should be secured with additional chains.
It seems like from what I can see in your photos that you are doing double duty with your chains. They are both holding the tractor and the implements...
I would not be comfortable doing this myself...but it could just be because I don't know better.
I would probably use four chains for the tractor, each which would go directly to tie points on the trailer, and additional chains to hold the implements.
My worry would be as you have the tractor chained down, with the chains running over the implements, that this could give additional opportunity to slack to develop in the chains as time passed when you were on the road...
   / Some constructive criticism, please #9
I second what HENRO said... also nice touch with the bungee cords on the ratchet.
If you get there... all the chains and work may be overkill.
BUT if you didn't... it only takes one scary ride to make you a believer.... You don't have too many chains on, and I was trying to figure out, with the way you are loaded up, how to get the four corners down to the sides of the trailer...
Does anyone think that cross chaining, like the safety chains for the hitch, on each side would help...
Pete.
   / Some constructive criticism, please #10
Deerlope,
Do you know where I can find the NY laws on towing/securing loads. I am not familiar with your statement on opposite securing of the load and could not find anything on the NYS DMV site on securing anything.
Thanks,
2010 Toro ReelMaster 132in Pull-Behind Hydraulic Reel Mower (A51691)
2010 Toro...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53473)
2020 New Holland...
2009 Ford F-350 4x4 Flatbed Truck (A51691)
2009 Ford F-350...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
Northern Ag 100 Gallon Mist Sprayer (A50123)
Northern Ag 100...
