Some BX2660 modifications...front weight and speedometer
   / Some BX2660 modifications...front weight and speedometer #1
Adryan
Iseki TX2140
Hi,
I just want to share some modifications I made to my BX2660
I wanted to add on some front weights without drastically modifying the front guard.
just look at the pictures. I use the quick connect bracket from the MMM to secure the weights.
Also installed a speedometer for using my sprayer. Mounted the sensor on the rear shaft, simply stickin some more magnets on the shaft to increasse accuracy.
Adryan
   / Some BX2660 modifications...front weight and speedometer #2
Really neat weight set, did you weld the tube to your grill guard? I like the way you fasten the weights with the front mount for the mower. I'd like to know more about the speedometer, I found one on Amazon similar to yours, but wondering how you calibrate it. Thanks for the ideas.
   / Some BX2660 modifications...front weight and speedometer #3
Very nice,especially the front weights :thumbsup:
   / Some BX2660 modifications...front weight and speedometer #4
I like the speedometer! :thumbsup:
   / Some BX2660 modifications...front weight and speedometer #5
Awesome mods, I love how you can have both weights on the front and still have your grill on to protect everything. Is the speedometer the same as a bicycles where you measure how many millimeters the wheel moves during one rotation and enter it in for calibration?
The speedometer I use is the o-synce mini save. Its a bicycle speedometer, but it's the only one I could find with a big display AND increases the speed in steps of 0.1 in stead of 0.5.
Calibrating is easy, just enter the wheel size in the computer. To make sure the speed is recorded correctly at slow speed I used 3 instead of 1 magnet (the small type of neodynium magnets ,10x5x1mm) just 'stick' them to the wheel shaft.
   / Some BX2660 modifications...front weight and speedometer #7
Great mods.
I like both of them. Now you've got me thinking about adding a speedo to my B3200 - and doing something like you did
for adding weights to the front end too.
   / Some BX2660 modifications...front weight and speedometer #8
Question: so I found the Osynce products online:
minifree - o-synce
And it appears to be a European product. Does the Mini-save allow you to display in MPH instead of KPH? Is there a calibration you need to do have it use the 3 magnet setup like you're using?
Jim,
I used the mini save instead of the mini free. Difference is the mini save is a wired version. So there is a wire between the sensor and the display, so no chance of interferance.
   / Some BX2660 modifications...front weight and speedometer #10
Jim,
Does it allow you to change to MPH instead of KPH?
How does the 3 magnet setup you installed work - do you have to setup the head unit to recognize that you're using 3 magnets instead of 1?
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
2009 John Deere 7330 (A50120)
2009 John Deere...
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
