Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,896
- Tractor
- Kubota BX25
GPintheMitten:
I've seen your thread on the R&D, part of the reason I'm interested in one. Why do you think it won't work for post holes? Too wide of a hole? I'm not doubting, just trying to judge some tools capabilities before I buy.
Seabee:
Yup, if I had money to burn... heck, even if I didn't have enough to burn but just had more than I could spend... I considered a BH, but it would add almost 50% to the price of a tractor and FEL. Even my local dealer suggested it wasn't a great idea, seeing as the turning radius is limited and one has to constantly move the tractor. He suggested renting mini-excavators for digging jobs. So... no BH for me. In any case I'm interested in your homemade implements... I assume you have some decent welding skills?
Jeff:
I like the Stabilworks stuff... but they don't ship across the border, so no use to me. I've read about folks upgrading Bxx20 3PH systems to Bxx30 3PH systems, so I plan to research that avenue as a possible upgrade for the turnbuckles... at this point though, I won't be switching off the rear implements that often.
You have to be a good welder if you want things to not break. A horz band saw, drill press, arbor press, torch, reamers, end mills for the drill press to use as a milling machine and the skills to use all that are also a requirement. I've done all these things most of my life and I am one of the old guys now. I am also going to build the telescoping sway braces like Stabilworks as soon as I find the right materials. I am also scratching my head over the rest of the cumbersome BX 3 point system. Want to get down the links and pins and no tools to hook things up.
Ron
