Solution to Sticking Fold Down ROPS Pins
   / Solution to Sticking Fold Down ROPS Pins #1
narcnh
west-central NH
Kubota 7800
I think I have a simple solution to the problem of the Pins/Bolts sticking, when you try to lower the ROPS. I just screw the bolt in far enough for the cotter pin to make it through the hole. This leaves 1/4 inch or more of play on the other side, but the pin holds it in place. If the ROPS snugs up against the pin, just turn the bolt the other way, before removing.
I was out on the tractor for around three hours last weekend moving snow off the driveway and again for three hours today moving snow away from the house (slide off from metal roof), and both times both bolts came out easily. Before this, one ALWAYS stuck.
Hope this helps someone.
   / Solution to Sticking Fold Down ROPS Pins #2
Hijack!
Metal roof on your house? And everyone thought I was nuts! Anyhow, mine is 53 feet each side to the peak, and when that snow slides off, what a pile. Did you ever consider snowbirds (snowguards?)
1272 (A50490)
1272 (A50490)
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2013 Volvo BL70B (A47477)
2013 Volvo BL70B...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
