solo operation of log splitter on a skid steer??
   / solo operation of log splitter on a skid steer?? #1
angustrees
E. Tennessee (relocated from IL/MI)
1971 JD 4020 Diesel, Kubota 3400 & SVL75-2, RTV-X1140, Case 650M, CAT 311
I have a flippable splitter used on my Kubota SVL75-2. I want to be able to control the splitter from the ground when the splitter is on top & I'm solo operating. Seems simple enough--just parallel the wires to the rocker control in the cab, RIGHT?? But where do I find that connection spot??? (Pic is from just before delivery of new SVL75-2 & 1140.)
This thread is in error & I can't delete it. Look at my other post with the picture. Sorry for the issue. I'll copy here.
   / solo operation of log splitter on a skid steer?? #4
Am I correct in assuming (hate that word) that your system is electric over hydraulic, and it may be a toggle type switch and not something on joystick?
There may be more to it than just extending (paralleling) the wiring to operate solo, does the unit have seat safety switches that may immobilize the splitter if you are off the seat or some such thing?
IF there is not a optional extension built in, you may have to open up control panel and duplicate the wiring to solo switch by actually doubling up connections on existing switch or splicing into the switch wire where it may be conveniently access able.... Would help if you had wiring diagram on how existing switch operates.....
Sure would help if I could get a wiring diagram -- anyone have access?????
On the -2 machine I can standup, put the handbars down & then activate the control switches & exit the cab - which means if I could link into those wires, I'd be in business. But I do want avoid damaging the complicated electronic control system - so I'm very cautious.
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2019 INTERNATIONAL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
