Solenoid valve controlled hydraulic top link for BX25?
   / Solenoid valve controlled hydraulic top link for BX25? #1
ashdump
East Central IL
Kubota BX-25
Will this and this along with the necessary plumbing and switching suffice for a decent set up? I don't really want hoses and bulky valve controls up in my operating area. I'd like to conceal as much of it as possible. I'd like a neat and clean looking appearance and a simple 2 way momentary on switch mounted somewhere convenient on the fender. Some of you guys are real wizards at this stuff. What say?:)
   / Solenoid valve controlled hydraulic top link for BX25? #3
Yes, BUT the valve body you linked is for CC (Closed Center) systems. You would need this one: 9-6136. Don't forget you also need the D03 subplate and two of the connectors. This valve is bigger than you think...so make a template of it to see where you are going to hide it-don't forget you will have 4 hoses connected to it also.
I bought this valve for my tractor since it was smaller: #9501651 But never got it installed yet-it's on the list...
   / Solenoid valve controlled hydraulic top link for BX25? #4
I noticed the retracted length is 18 inches, will that fit a BX25? I know that is too long for my use on a BX2660.
Thanks for the info.:) I know no matter what, there will be a lot exposed somewhere, I just am not crazy about it being largely in my operating space. With the BX, I also know there's not a whole lotta room to conceal or open mount this stuff. Now my wheels are spinning again, I wonder if there is a 12V linear actuator that would work and be strong enough to do the job? That would eliminate the plumbing altogether!
   / Solenoid valve controlled hydraulic top link for BX25? #7
Short answer is NO...There are other threads on this and installing valves-I suggest you search for them (Not blowing you off, just there is a LOT of info in the older threads)
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
Pallet Fees (A50774)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
2022 Robex 55-9A Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2022 Robex 55-9A...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
