Solenoid question
   / Solenoid question #1
Scarob63
1960 Ford 641
Currently 6v positive ground electronic ignition, push button start.
I have 4 post solenoid and it only operates when ignition wire is connected through other post. Question, is that a problem with E ignition or should I change to 3 post solenoid, or ground this terminal? Thx
   / Solenoid question #2
If powering one small terminal and grounding the other completes the circuit and activates the solenoid I'd probably just ground the terminal. The three point solenoid just has one terminal grounded internally.
   / Solenoid question #3
Not always, if this were on an 2N/9N/8N tractor the solenoid is wired differently.
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
