Solenoid on injector pump on nh tc 40d
   / Solenoid on injector pump on nh tc 40d #1
hoot1293
HAs anyone replaced the solenoid on injector pump on nh tc 40d. Can you change it without taking pump off and do you have to bleed the lines after doing it. This is a 2002 nh tc 40 d. This is a one wire hookup solenoid. I have checked the voltage to the solenoid and it is working.
I hope someone knows about this and can help me
   / Solenoid on injector pump on nh tc 40d #3
There should be no need to take off the pump to replace the fuel shut off solenoid. If it's working why replace it?
   / Solenoid on injector pump on nh tc 40d #4
The solenoid simply threads into the block. It has no connection to any fuel passages, so no bleeding is required when removing and/or installing. A pair of channel locks will usually break it loose.
It only works part of the time, I have to grab where wire hook and move it and then it works
Thanks for the help
   / Solenoid on injector pump on nh tc 40d #7
Hoot, have you checked for voltage at the wire terminal when it does work and when it doesn't? Wiggling the connector makes me suspect a broken wire or bad wire-to-terminal connection.
Jim
I have 12 volts when I turn key on.
2011 BMW 750Li Sedan (A55973)
2011 BMW 750Li...
48in Forklift Safety Basket (A56857)
48in Forklift...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
John Deere 4510 (A53317)
John Deere 4510...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
Sterling T/A Drill Rig Truck (A55973)
Sterling T/A Drill...
