soldering aluminum?
/ soldering aluminum? #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Here's an unusual problem: I am installing solar heating in my shop- two big flat plate collectors, circulating oil via a pump, heating via a small oil cooler with a fan behind it. I bought what seemed to be the perfect cooler thru eBay- an Earl's NASCAR flat plate oil cooler, cost $400+ new- used but said to not leak. When I finally got the AN hoses to hook it up to some air pressure under water, guess what? The leak is small, just where the AN fitting is brazed to the top of the cooler. Since these units are factory furnace brazed under computer control, fixing them isn't easy. Earl's suggests an industrial epoxy (?) which doesn't sound good to me- I don't want to go out some day and find 2 gallons of solar oil on the floor. I am wondering if anyone has ever used aluminum solder. I think it would melt at a lower temp. than the brazing, so maybe, if I am really careful with my heat... looks like a natural place to puddle a little solder. Otherwise, I have some recycling material.
/ soldering aluminum? #2
I've used this and had decent results. He calls it "welding" but seems more like soldering to me. It worked for me repairing a cast aluminum part that had spider web cracks in it when silver solder didn't. His marketing comes off a bit like snake oil but the products do what he says after a little learning curve. I'd practice on something else first and CLEAN EVERYTHING! After you get the hang of it it flows out like silver soldering copper, getting into all of the cracks and joints, just at a lower temp. (350 deg F). He has another product that melts at 600 deg also it seemed to work O.K. but I haven't actually repaired anything with it just played around so I can't say it "works".
Hope it helps.
Muggy weld
http://www.muggyweld.com/1aluminum.html
/ soldering aluminum? #3
If I understand the scenario, the leak is right where the fitting is brazed on?
So, in that area, you have the aluminum base for the radiator, the aluminum fitting and the brazing material that they brazed it together with?
Assuming that, I would not want to add another material into the mix. Often times, it is hard to sort out what is what and those things turn into a mess.
My first choice would be to call back earls, and ask if you could get a little of the weld material that they use, and then apply that with a TIG and it would be a sound repair.
Second choice, if there is a little bubble of material there, you can sometimes chase it across with a TIG and seal the hole.
Third choice, I would hazard a guess that it is Silicone Bronze, and get someone with a tig to drop a drop of silicone bronze on the top and seal up the hole.
I would be skeptical of the solders and the adhesives but that is me.
Hope it works, if you need a stick of silicone bronze let me know I keep about 10 lbs usually.
If you look for a thread I did that said interesting welding (kind of) you will see where I talked about a similar process.
/ soldering aluminum? #4
Looks like the product KLM suggested is a pretty good idea.
The problem I can see trying to use a solder for a crack repair on aluminum is that yes it melts at a low temperature, but you can't get the parent material hot enough for it to bond properly. The oil cooler is an example in that link KLM shared, where the heat is dissipated rapidly. Sounds like I would give his product a try.
Otherwise, I would braze it.
/ soldering aluminum? #5
I have soldered stuff to aluminum heat sinks.. it ain't easy.. but it is doable.. clean the surfacs.. a lil super fine sand paper helps.. lots of flux too.. I'd use silver solder.. or those alum-alloy rods and attack it with mapp or propane hand torch.. once it gets to a certain point that the solder will stickto the aluminum.. you got it made.. usually just outside the crown of the flame.. deffinately not as easy as sweat soldering copper.. etc..
soundguy
FWIW, I did talk to Earl's, and they told me that since this thing is made from a quadzillion parts, all furnace brazed at one time, if I heat it up enough enough one place to melt the brazing then I will get problems in 4 other places. Much of this thing is inaccessible, so there you go. The leak is where a machined fitting was brazed to a plate, or sheet of alum. with who knows just what underneath... so I am leery of too much heat. Earl's said you can't weld these things without disaster. If I could just heat the fitting until solder would flow, at a lower temp. than the brazing material, I should be okay. This will be a low pressure system- 10 lbs or so, and temps under 250, so maybe...?
/ soldering aluminum? #7
At 350 degrees, I'd just solder it up, then toss it in the oven to make sure the surrounding metal got that warm to make a good flow. None of the other brazed joints should be affected at 350 I would think....
/ soldering aluminum? #8
I agree.. solder should melt WAY before any brazing materials..
soundguy
/ soldering aluminum? #9
you can get these aluminum welding sticks on ebay and other places, which you use with a MAPP torch to weld aluminum. they work
mike
/ soldering aluminum? #10
Alumaloy is the one that I mentioned.. but I have seen them all over.. even fleay markets.. I saw a guy solder up a hole in the bottom of a soda can with one of them..
soundguy
Thanks for the advice, folks. I think the Muggyweld stuff would be the best route, but at $50+ for the smallest order, I hesitate to go that way. I would be willing to invest another $10 or so in aluminum solder (this is a small hairline crack, so it wouldn't take very much solder to fix, if it's gonna fix) before I give up. I can buy a nice new cooler that will work for about $80 (I didn't do all the internet research before buying the Earl's- and it's a nice, NASCAR grade unit... but this is a shop, after all. What to do??
/ soldering aluminum? #12
If you have a northern tools store nearby.. hit it.. they sell the aluminum alloy solder rods... Also check welding supply houses for it... perhaps flea markets..e tc.
Soundguy
/ soldering aluminum? #13
I've bought muggy stuff before. Complete and total waste of money. Just my opinion, but for the same or less money, take it to a custom weld shop and have them spend 5 min on it with a tig.
jb
/ soldering aluminum? #14
J B is right. You need it right the first time with not having to wonder if you'll have oil on the floor.
/ soldering aluminum? #15
I'm afraid that the oil in the Aluminium pores will keep coming out and foil any chance of welding . Is there a possibility of drilling the crack and tapping for a tapered plug ? Depending on the length and position of the crack you should be able to find a brass plug to take the place of the crack . If need be Lock N Stitch have Aluminium plugs that are screwed into the crack . The first one goes in and is ground flush , the second is drilled into the side of the first and so on until you reach the other end . The finished job looks like a series of half moons all joined together .
/ soldering aluminum? #16
I think horse has a point.... most every welding shop here has alum welding rods for gas.
/ soldering aluminum? #17
Ones like this, Hy-Poxy Systems, Inc., will do what you want. Applying a slight vacuum to the piece while patching will help draw epoxy into the repaired area. Check with a HVAC supply house, not lowered standards (Lowe's) or home dumpo...
/ soldering aluminum? #18
I am currently running a company that manufactures thousands of aluminum and stainless heat exchangers per year. When a heat exchanger has a leak at the braze joint we sometimes put pressure on it in a restraining fixture and then bake it again. If the leak is easy to get to from the exterior we TIG weld it. I would guess that even our very experienced repair people loose over 1/3 of what they try to fix.
/ soldering aluminum? #19
Every time I've ever welded or brazed / soldered oil lines.. i just use a torch to burn out the crack first... never had a problem with doing that..
soundguy
/ soldering aluminum? #20
Sound,
That works for steel, but aluminum will melt before you can burn off the oil. Silly to make stuff out of it...
Professional shops will have degreaser tanks. They do it often. May or may not be successful, but a pro with a Tig would be my 1st and 2nd choice. 3rd choice involves cuss words, more oil on the floor and the puchase of a new one....
jb
Water/Sewer Milwaukee Tap Machine (A61166)
Water/Sewer...
2002 Sun Coast Trailers T/A Enclosed Trailer (A61569)
2002 Sun Coast...
2025 LandHonor LHR-WG1507 Walk-In Greenhouse (A60353)
2025 LandHonor...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
CENTRAL PNEUMATIC 21 GALLON ELECT. AIR COMPRESSOR (A62131)
CENTRAL PNEUMATIC...
GMC V6 MOTOR (A62131)
