Solar Tractor Battery Maintainer?
/ Solar Tractor Battery Maintainer? #1
Larry Caldwell
Super Member
Myrtle Creek, Oregon
Kubota l3130
The shed where I store my tractor does not have electricity. Parts of the year the tractor is not moved. When spring rolls around, I have to deal with a dead battery, often sulfated. Then it's jumper cables time, the battery bounces around in the field mostly discharged, the lead sulfate sheds off the plates, shorting them out, and it's new battery time.
I'm trying to decide what unit to buy. There's the $20 Coleman 1-watt unit, with no charge controller at all. There's also the $125 one at Northern Tool that advertises fairly sophisticated battery management at 0.45 amp max. That's impressive, but I could probably buy a couple batteries for the price of the maintainer.
Does anybody have any experience with this?
/ Solar Tractor Battery Maintainer? #2
On every item I don’t use during the winter, I pull the batteries and place them all in a shed. There I rotate a battery maintainer through the lot during the winter. I get 7-10 years on my batteries. My chargers all put out 2.5 amps. I’m just wondering how a low amperage unit will work.
/ Solar Tractor Battery Maintainer? #3
I'm with grshthegreat. I pull batteries from unused equipment in the winter and store them in my slightly heated well equipment room. Disconnected they hold a charge over the winter. I top them up in the spring and I'm good to go for the season. Solar chargers seem to work best where there's lots of sunshine. We have a LOT of overcast days in the winter which will reduce solar charger output. Also, you couldn't place the charger IN your shed. It would probably go on the roof or some other area exposed to the sun. Someday I'll run power to my tractor shed - maybe.
/ Solar Tractor Battery Maintainer? #4
Being an electrician.... I have power Everywhere . Even to front planters. I can control barn lights from house. All sheds, including wifes greenhouse and planting sheds are wired. I cant see how anyone can’t have power at any shed. There’s always something needing plugged in. I never have figured out how many miles of underground wires I’ve run. I even ran some under the front road to an additional 10 acre parcel I own so I can heat water trough and electric fence.
oh, and the wifes lighted arena. When I added that load to my shop I had to change shop from 50 amps to 200 amps.
/ Solar Tractor Battery Maintainer? #5
Tried one on the generator's huge battery that powers both its little LCD panel and the auto start panel in the house. Was not enough. Think it was about a 10 watt one, not one of those little 5 watters. Put it out on the gate's battery in parallel with the one they supplied.
If you get one, get a big one.
/ Solar Tractor Battery Maintainer? #6
Bought the Northern 15 months ago for brother and sad to say it is still in box...
The idea was to keep two six volt batteries in 1950's tractors charged in series as 12 volt...
The shed is on a hilltop 1000 yards from house...
The bonus was hooking up a 12volt LED for some light using Tractor batteries.... wish I could provide in the field reporting..
Have not visited since Feb 20 2020...
/ Solar Tractor Battery Maintainer? #7
I'm using the Battery Tender brand single 5A solar controller with a 30W panel. I put SAE pigtails on my tractor, backhoe, and car that sits in the barn. I have a lead that is long enough to reach the car and the backhoe and an extension lead that will reach the tractor.
I put a toggle switch between the panel positive lead on the controller.
The controller has a simple LED that indicates if the battery is charged. Every now and then I turn off the panel, switch to a different unit, and turn the panel back on. When I notice the LED is green I will move it again.
/ Solar Tractor Battery Maintainer? #8
I NEVER pull batteries unless they are dead!
I have 16 Battery Maintainers/Battery Tenders, some only .75A, but most 1.25A.
When I anticipate a machine will be stored for more than 30 days it gets a Battery Tender/Battery Maintainer, until it is used again.
On average, my batteries last 8+ years.
/ Solar Tractor Battery Maintainer? #9
I use solar powered battery maintainer all the time, and these trickle charges will definitely keep your battery in top condition. My zero turn, RV, Boat, tractor and my tow vehicle all have them. Buy one big enough and with high quality and they will charge your batteries for many years.
/ Solar Tractor Battery Maintainer? #10
/ Solar Tractor Battery Maintainer? #11
I generally have power everywhere, but the barn is across the creek from the house. Getting power to the barn is more complicated than running wires. It would be nice to run a water line out there too, but with the creek, livestock is not going to go thirsty.
I ran 200 amps to the shop, 30 amps to the wood shed/garden shed, and 120v to the gazebo, but power to the barn is going to require a 60' clear span bridge just to support the conduit.
/ Solar Tractor Battery Maintainer? #13
Oh...that would truly be a pain. How do you get the equipment across the creek.im glad I don’t have to deal with a creek.they truly are beautiful, and also a pain.
here in idaho, if you have a running creek, you can’t use the water in most cases. Especially for irrigation.
/ Solar Tractor Battery Maintainer? #14
I have one from autozone that works fine but my battery is on a dump trailer that doesn't have a parasitic load. A tractor might be like a car, it's constantly drawing power for the ECU and other electronic stuff, so you might want to either disconnect the battery when it's on the charger or measure the parasitic drain to make sure the panel you buy can keep up with it. One thing to make sure of is that the unit comes with a charge controller that prevents discharging the battery during the night. What solar panels giveth, they also taketh away, so they will discharge the load at night if the battery isn't cutoff by the charge controller. Mine is 2W, that's plenty of power to keep it in float mode through the winter. You don't need sunshine all the time, the panel will work on an overcast day and a battery will go quite a while when it's fully charged without needing a float charge anyway.
/ Solar Tractor Battery Maintainer? #15
Been using one for years. Talked many friends into them also. Awesome tool. Set it on the dash and forget about it.
Just make sure they have a controller and the reverse diode.
I believe I spent around $40 for them.
Of course, you'll have to get a weatherproof one and mount it outside.
A county road runs through the middle of my place. A couple hundred yards upstream the road crosses the creek, and I have driveway access on both sides. The barn is about 400 yards downstream of that property line.
/ Solar Tractor Battery Maintainer? #17
I don’t think you would have anything to loose, the battery isolation is a good idea too! Im actually looking at a similar set up for my tractor/shed until I can get power in a few years, only I’m thinking a little larger scale... a couple of 100 watt solar panels, a few deep cycle or even golf cart batteries, and an inverter. it will surprise you what it will run for relatively inexpensive upfront cost. Not only will it run a battery maintainer, but also some lights too. depending on how big you go could run 15A plug for misc periodic tool use
Good point. Somewhere in a junk drawer I have a 700 watt inverter that I'm not using, plus having a topped up battery means jumper cables might be all I need...
I hadn't thought of setting up the barn off-grid, but by the time I buy 360' of direct burial cable and rent a trencher, solar panels might be cheaper. I could string some 12v. wire and have LED lights out there on a switch.
Thanks for the suggestion.
/ Solar Tractor Battery Maintainer? #19
The idea of solar panels is not totally bad....but...
Think forward!
What might you like to use out there in the future?
I shopped for a good deal on 500' of direct burial cable.
Rented a trencher, and did the job ....37 years ago.
I have a 100A barn service panel, and can use a welder, or whatever else I might want.
Think forward!
Everybody's situation is different. I have a 36 x 60 shop with a 200 amp service where all the welding and heavy power draw is. The barn is just a barn - hay and equipment storage mostly. It's a good place to keep stuff dry, and that's about it.
