Solar-powered water supply
   / Solar-powered water supply #11
These were made to do exactly what you want. Will work directly off a solar panel(s) using their controller....no battery needed. 40-100w of panel will get you 1/2gal-4gal/min (depends on model) if you have less than 20' from pump to water source. They can pump over 500' height, at reduced rates.
Dankoff Slowpump 13�3-24 24VDC SURFACE PUMP | altE
Click on the "Documents" tab for PDF's on how to install.
Except for the price (!), that is pretty close to what I was thinking of. The price doesn't include the solar panels, either.
I think I'll try a cheap 12V pump with battery and solar trickle charger...but I'll do some rough power usage calculations first before I decide on wattage of the charger.
Thanks, all, for the comments and suggestions.
   / Solar-powered water supply #13
I'm working to fence in some new pasture for horses, but it is nowhere near a power supply or well. I'd like to pump water into a water tank (about 150gal) from a stream and am thinking of setting up a solar-charged battery system to run a marine bilge pump (I'd need less than 2m of head). Ideally, I'd alter the switching so it pumps when the water level is down, rather than up (as in a bilge), but I'm hoping for insights about the pitfalls of doing this water supply the way I'm envisioning it.
Any special advice, caveats, etc.??
Thanks.
How about a hydraulic ram? I have seen them work well in Brazil where there isn't any electrical and sometime rains for a month.
The Ram Company, Pumping Water without Electricity.
There isn't really enough head to operate a ram pump well; it would be challenging to go far enough upstream to pipe even 3 or 4 ft of head down to a pump. It is too bad; ram pumps can operate continuously for a long time, and continuous flow into/through my water tank wouldn't be an issue...in fact, it would help keep the water fresh and cool.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2006 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2006 CATERPILLAR...
John Deere 7130 (A53314)
John Deere 7130...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
