Solar powered fence charger
   / Solar powered fence charger #1
BeezFun
IL
Kubota B2710
Looking for a solar powered fence charger I can move around the pasture when I put up temporary partitions during grazing season. Only need to charge about a mile of line, I'll be using wire rope, maybe some tape. Anyone have any brands they've been happy with, or suggestions on features, what to avoid, etc? tnx
   / Solar powered fence charger #2
We've got a Parmak model 12, no troubles with it for about 2 1/2 years now.
   / Solar powered fence charger #5
Sorry - wrong one.
The one I have is solar.
6V DC Solar-Pak Fence Energizer | Princess Auto
It remained outside in the snow/rain and cold and was charged(needle went beyond the green zone in the meter) when I turned it on.
A buddy has the same manufacturer but his is 12v and charges a car battery but it didn't hold a charge well when the wire got grounded. When the needle goes in the red you know something is grounding out the unit. I used mine last year to fence in two pigs. When feeding I would check meter and correct fence line problems/grounding if need be. After correcting, the needle would go back into the green - worst case - needle would be in middle of green zone. Even with a few cloudy days it would work/charge. I put it on a post with s'east direction as recommended in the instructions.
Hope this helps.
   / Solar powered fence charger #7
   / Solar powered fence charger #8
A buddy has the same manufacturer but his is 12v and charges a car battery but it didn't hold a charge well when the wire got grounded. When the needle goes in the red you know something is grounding out the unit. I used mine last year to fence in two pigs. When feeding I would check meter and correct fence line problems/grounding if need be. After correcting the needle would go back into the green - worst case - needle would be in middle of green zone.
Yes that meter does serve a purpose. If I let the grass and weeds get tall enough to touch the fence, and there's a dewey morning, the meter will drop into the yellow or red letting you know something's not right.
Ours is on 24/7/365.
   / Solar powered fence charger #9
Correct. I used my whipper-snipper to keep the grass down and would removed branches and rocks that the pigs would push onto the lower strand of wire. Clever them pigs!
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
More info coming soon! (A50323)
More info coming...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
