Solar hot water system started!
   / Solar hot water system started! #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Here are some pics of the first of three 4x8 foot panels for my solar hot water heating system.
   / Solar hot water system started! #2
Cool! :cool:
How exactly does it work? It is it directly heating the water or does it generate electricity for a heating element? Is there a "power" back up and do you get enough sun in Wisconsin?
   / Solar hot water system started! #3
Doc,
That looks like a good project. I think we're leaning towards solar for our radiant heat too. BTW, who is that old guy on the roof? Is that your Dad? <BG> Ha Ha. :)
   / Solar hot water system started! #4
very, very cool. More info & follow-ups please! Links?
bloody_peasant said:
Cool! :cool:
System heats Proplylene glycol (used in food, won't freeze) then goes to the heat exchanger in the basement and heat is transfered to the potable water. More pics soon!
Bob
3RRL said:
Doc,
Old guy is friend. I will let him know you think he is old, he won't disagree. Excess heat will be used in radiant heat system for living room with PEX tubing beneath floor between joists.
Bob
Cool! :cool:
We get enough sun in Wisonsin. I have a natural gas water heater as back up, the solar system is connected to the gas heater and the solar system provides heated water to the gas water heater. If the solar heated water is warm enough, then the gas water heater does not turn on. The solar water heater does have an electrical element in it, but I do not have it hooked up as electricity is too expensive to heat water.
Bob
   / Solar hot water system started! #8
Sounds like a very simple system. I know very little about solar heating but your plan raises some questions:
Does your circ. pump run continuously? How do you keep the water from getting scaldingly hot?
What about at night and very cloudy days in winter? I'd think the system would act like a big chiller at those times, causing your electric element to kick on, very, very often.
pump runs only when glycol is hot and needs to transfer heat to storage tank.
Storage tank water can approach 160 degrees (just from sun) and there is a "tempering" valve that mixes cold water with hot water. Prevents scalding.
On cold nights, pump does not run, so no cold glycol brought to tank. Also has an antisiphon valve.
Bob
   / Solar hot water system started! #10
I take it the glycol method is more efficient for heating water than using electric solar panels to power the electric element?? Just curious on the reasons for glycol vs. electric... Interesting stuff though.
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2015 Freightliner Cascadia 125 T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
