/ Solar Generators - any members on site share experience and knowledge on what to purchase what run away from
#1
Depending on your ideal use, they can be a help or just a fad.Seems like they’re is a lot of advertisement on Solar generators. I have gas unit but my son believes we need solar generator. I ask fellow members to share thoughts on what is worthy of purchase.
I'm with @bmaverick; it all depends on what issue you are trying to address.Depending on your ideal use, they can be a help or just a fad.
Buying the Harbor-Freight Thunderbolt 100W solar power KIT, an inverter, a battery and small dolly cart, you can be just as portable and run so much too.
Thanks for the link will visit Otto learn more. Never thought of building portable unit either. That might be more cost effective. Keep the ideas coming thanks again.Problem is that solar generators are not generators but battery power packs with an inverter plus a SCC (Solar charge controller). Thus rather limited in power since it takes a lot of batteries (even LiFePO4) to contain much power. Yes, you can hook up solar panels to them for battery recharge and some load carrying capability. Keep in mind that ratings for these are often based on the inverter and not how much total power they have. A 3000 watt inverter is only as good as the supply you give it. Loads drive supply needs.
If you really are interested in PV (solar) there is a lot to learn and probably a good place to start would be over at the solar DYI forum DIY Solar Power Forum.
Are those any good? I bought a HF solar maintainer a few years back and it was useless. Voltage output was lower than the battery voltage.Buying the Harbor-Freight Thunderbolt 100W solar power KIT, an inverter, a battery and small dolly cart, you can be just as portable and run so much too.
