Solar battery charger
   / Solar battery charger #2
Many people use the solar panels to recharge the battery for their boat lifts around here.
   / Solar battery charger #3
Small world, I just bought that exact model about a month ago. I got mine off of Amazon, for about the same price and free shipping. It seems kind of cheap to me but it does work, I put a volt meter on it to make sure it was putting out power. If my math is correct, it puts out about 0.5 amps at best, which should be good for a maintance charger. I am a land surveyor and I use it to help keep our GPS base radio battery charged when it is setup.
Thanks Dodge! Unfortunately, half an amp won't be enough to charge my battery. Guess I'll have to stay with the plug in charger.
   / Solar battery charger #5
Another option might be a larger solar panel. I saw some pretty good sized ones for around a $100. They wouldn't be very portable but if you don't need it to be, might be a good setup for you.
Shop around for a folding one like this; US prices are almost always significantly better than here (even after considering the exchange rate).
Coleman 40W Folding Solar Panel | Canadian Tire
Bob
Thanks! I guess what I was looking for was something that was small enough to stay with the trailer. I got caught once with the battery dying as I was trying to lower the box and thought a solar panel might be the ticket. I'll just have to pay more attention to the battery and stay ahead of the charging.
   / Solar battery charger #9
A solar panel as a maintainer is a good idea for a trailer that sits outside, but as you know 1/2A won't actually charge it from a low state. 20 watts is 20/12=1.67 amps which might charge a battery but it's minimal. One way to know is if you hook it up and see it ever gets to a voltage higher than 13.2v. At 13.2 at least it's charging, but slow. And if you measure the amps going in you can know "something".
This is not really a suggestion but more of an illustration as to how much effort you'd have to throw at it to charge the battery thru the 7-pin. It can be done. Could be useful for a guy who can't park a dump trailer near 120v.
To charge the battery while driving you would have to significantly increase the wire size to your 7-pin. You will need to add 2/0 AWG wire, which is huge, more than 1/2" diameter ( ! ,,,,like a winch cable ! ) . And you need to increase the capacity on the trailer side too. Piggyback bigger wire wherever you can and you will get more amps at the end. I think you can get something like 40A thru one of the pins on a 7-pin connector that would give it a hot shot while you are towing. An 80Ah battery will (ideally) charge in 2 hours (if it can accept 40A but of course its never that simple). Here's the some info from etrailer.com. If you don't increase the wire size (a lot), the normal trailer wiring will only "maintain" the battery because of the distance (~20 feet). To ----charge---- the battery you will have to use 2AWG to reduce the losses over the "distance".
Lets say your trailer battery is 20 feet from your Truck battery, which may charge at 14v. If you can get 18 feet of 2/0 AWG and 2 feet of 10awg your (40A) voltage drop from 14v will be .11v from the 18 feet of 2/0AWG and .16v from the 2ft of 10AWG leaving about (14-.11-.16=) 13.73v for charging, which is not bad. The pins on your 7-pin trailer plug need to be "clean" and make a good connection.
You don't have to remove the black wire from the trailer circuit, you can add this large 2ga wire in parallel where the current flows thru both the 10ga trailer wire AND the 2/0 cable.
A simple way to get some charge to a low trailer battery is to connect battery jumper cables to the trailer and idle the truck for 15 minutes or as long as you can. 1) Good clean connections; 2) larger jumper cable wire; and 3) shorter jumper cables will all increase the amount of amps that enter the trailer battery within the time alotted.
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
2015 Ford E350 Cutaway Van (A52377)
2015 Ford E350...
