Solar battery charger
   / Solar battery charger #2
I guess it depends on what you plan to do with it. You can buy solar panels for $1 a watt - this one is only 5 watts.
   / Solar battery charger #3
I have an electric fencer that uses a solar panel to charge the battery. It works great. Never have to go to the far end of the property - exchange the battery & recharge the first one. Its been on the fence 41/2 years now. I do have all the controls in a weather tight Tupperware tub. Only the solar panel is outside. My only thought is - if you keep your tractor under cover - is the wiring long enough so you can get the solar panel out in the sunshine. Otherwise, I think this is a good idea and sure will extend the life of a battery. I've used Battery Minder chargers - they are good units.
They said they have a 20 foot cord on the solar panel.
Yes it will mainly be to charge the tractor battery.
   / Solar battery charger #6
This set up is a combination of a charger, de-sulphantor, and solar panel.
You can buy larger panels at a dollar a watt (or less), but the smaller ones still run in the several buck/watt range.
Also this one says it supports 2 batteries. Reviews were good on it.
   / Solar battery charger #9
This one is $24 a watt. Expensive de-sulphantor.
   / Solar battery charger #10
I guess it depends on what you plan to do with it. You can buy solar kit for $1 a watt - this one is only 5 watts.
Is that really possible? Can you tell the best place to get these panels?
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
2018 Freightliner M2 106 Rollback Truck (A50323)
2018 Freightliner...
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
