Soft Treadle
   / Soft Treadle #1
Glink
kubota L3400 HST
My 2005 Kubota L3400HST Treadle went soft at the end of my last mowing session. Lost power in forward and reverse; tractor will move but cannot generate speed or power. First real problem with tractor since purchase in 2005. Tractor has a little less than 500 hours on it; most of it mowing a flat and smooth 5 acrea yard. All inputs appreciated.
   / Soft Treadle #2
I've heard there's a blue pill for that.
You did say all inputs.
   / Soft Treadle #3
Similar to the symptoms I had with my BX1500. The mechanic said it was a failure in the bearing cradle that varies the displacement of the hyd drive pump as you push the go pedal. For me it was 6/6 replace trans. For your much larger trans I think it would be replace the internal failed component.
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
New Idea Pull Type Hay Rake (A50515)
New Idea Pull Type...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
