Backhoe Sod cutting attachment for backhoe bucket.
   / Sod cutting attachment for backhoe bucket. #1
OrangeJbird
NW WI
3320 w/300cx FEL
I'm trying to come up with a sod cutter that would quickly attach to an 18" bucket and peel the sod on 36 x 96" graves. Only found one patent Sod cutter - Hoke, Clyde Rockwell from 1977 online and it's far too complex for what I want to make. Would a sharpened 1/2" bar pull through sod? Or would it need a vibratory motion?
Maybe something like this?
Sod cutting knife
Thoughts/critiques welcome!
   / Sod cutting attachment for backhoe bucket. #2
Sod cutting knife
This is not my build but you can likely adapt something like this to a backhoe.
See this link: http://www.tractorbynet.com/forums/build-yourself/229455-sod-cutter.html
   / Sod cutting attachment for backhoe bucket. #3
Might be easier, quicker to start with a buket cutting edge, then follow the idea posted above. Add another cross member above it with couple clamps to clamp on your backhoe bucket. Should do it.
   / Sod cutting attachment for backhoe bucket. #4
You want something quick, easy on and off and something light so you actually use it. The one pictured looks like it would work good and be easy to build. I would just make it so that it hooks over a tooth to pull it. Something with a round disc on each side would cut nice and clean too. Then just use the bucket to remove the sod, likely wouldn't need the sod root cutter.
   / Sod cutting attachment for backhoe bucket. #5
   / Sod cutting attachment for backhoe bucket. #6
Sod cutting knife
We own five cemeteries in Georgia and use a Komatsu excavator to dig our graves. We have had no trouble taking the sod up with just the toothed bucket as long as we pre-cut the sod with a spade. Normaly cut around perimeter and then down the middle of grave and then across about every 18". I built a steel frame as atemplate for the grave. Quick and easy
Nice ideas.
Thanks all!
What width bucket do you use?
   / Sod cutting attachment for backhoe bucket. #9
we use a 36" inch esco bucket but with the weld on cutting edges on each side, digs 37". The bucket is actually called a "cemetery" bucket. We use a Komatsu PC 35 to dig and it works great. Leaves almost know footprint and easy in and out.
   / Sod cutting attachment for backhoe bucket. #10
Thanks for this post guys I was going through the same thing
2012 Freightliner M2 106 Terex Hi-Ranger TL41 41ft Insulated Bucket Truck (A55852)
2012 Freightliner...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
Schulte SBW800 Rock Windrower (A57024)
Schulte SBW800...
1624 (A57192)
1624 (A57192)
Mini Margaritaville Truck (A55853)
Mini...
