Sod cutter ideas? BX2200
   / Sod cutter ideas? BX2200 #1
lww05
East Texas
BX23
I have a good-sized former garden spot that is so thick with Centipede grass. I'd like to move some of it using a sod cutter and my FEL. I looked through the Woods website and didn't see anything. I am considering trying to piece something together that might work. I'd like to be able to adjust depth with a set of additional wheels or skids.
Any ideas on an already built unit somewhere or plans for building one?
   / Sod cutter ideas? BX2200 #2
You can do this with the FEL alone unless you want to save the sod for use elswhere.
I used to prep gardens by removing the sod with a flat spade. Back-breaking, tiresome work. Once I got the BX2200 I removed the sod for a flower bed in 3 minutes. Would have taken all day with a spade.
Phil
   / Sod cutter ideas? BX2200 #3
After planting a new tree in the front yard, I noticed that my BX would hardly move.
I had left my Woods 48" box blade down by mistake, and had a whole box full of sod to show for it. Managed to put it all back before the wife saw it and had a fit.
Correctly adjusted (angle) that blade makes one heck of a sod buster.
/forums/images/graemlins/grin.gif
I did forget to mention that I wanted to keep the grass for planting elsewhere. What would be ideal is an implement that would cut the sod in continuous lengths and have about the same width as plats of grass you buy. The FEL could cut the pieces to length. With a decent depth control to keep the topsoil fairly thin under the root system, and a little back work of rolling sections up, all that would be left is loading them and then rolling them out where needed.
   / Sod cutter ideas? BX2200 #5
See if the rental places have something to do this. We've got sod farms all over the place by me but I've never seen what kind of machine they use to dig it up. I see it disappear year after year and get replanted.
   / Sod cutter ideas? BX2200 #6
they do sell an implent that does what your looking for but they are big money & you need a 40 hp + tractor to run it. My advice is just rent a walkbehind sod cutter. Every rental center has one. They cut the sod in to neat strips just like you buy it. I have rented them many times & replanted the sod & had great success just remember sod needs about triple the amount of water that dry seed would need.
   / Sod cutter ideas? BX2200 #7
Oh now that's a good one! I ain't done that, just yet.
My FEL has gathered a few shovel full size hunks of sod when mowing.
</font><font color="blue" class="small">( After planting a new tree in the front yard, I noticed that my BX would hardly move.
/forums/images/graemlins/grin.gif )</font>
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
(1) 300 Gallon of Double Concentrated Car Wash Soap (A51573)
(1) 300 Gallon of...
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
