Socket sizes for B7500 HST???
   / Socket sizes for B7500 HST??? #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
50 hour maintenance is coming up fast. I need help on socket sizes required. Are the following correct: 26mm for transmission strainer, 17mm for front wheel bolts, 22mm for rear wheel cam nut, 22mm or 23mm (???) for rear wheel bolts, 30mm for RCK60-24B mmm blades? Are there any other sizes in this or future maintenance tasks? Also, where is a good place to find these socket sizes? Thanks in advance for any assistance!!!
   / Socket sizes for B7500 HST??? #2
I use to get all of my singles and odd stuff at Sears. I have been getting most of them from Lowe's lately. The sockets from Lowe's as are a pretty good quality and last well.
   / Socket sizes for B7500 HST??? #3
just get a good set of metric sockets from sears or form your local auto store. and rest assured no matter what set u get , u are always going to be short at least one size! /forums/images/graemlins/frown.gif never fails /forums/images/graemlins/grin.gif
   / Socket sizes for B7500 HST??? #4
Also need:
19mm and extension for oil drain plug
17mm for 2 Hydro drain plugs near mid PTO
14mm for drain plug near left drive shaft
The 50 hour service is a snap.
Good luck
   / Socket sizes for B7500 HST??? #5
I believe a 3/4" socket will work for the 19 mm bolts. I just finished working on my Honda Accord and they use a 32mm nut on the drive shafts, which just happens to be equal to a 1 1/4" SAE size.
It seems that most of the larger metric sizes I run into have an SAE equivalent.
Before running out and buying a large size metric socket or set, it might be worthwhile to convert the metric size to SAE and see if it's equivalent to a size already in your tool box.
Every once in a while ya' get lucky. /forums/images/graemlins/smile.gif
~Rick
Thanks to all who responded!!! /forums/images/graemlins/cool.gif Just found out that my youngest son has all the socket sizes identified, plus most everything in between, too. It's about time to borrow some of his tools. Thanks again! /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/cool.gif
   / Socket sizes for B7500 HST??? #7
thats strange! a father borrowing tools from the son, usually is the other way around. /forums/images/graemlins/grin.gif
   / Socket sizes for B7500 HST??? #8
frank_f15,
Interesting you should mention that! That 1 1/4" socket I needed I had to borrow from my Dad. /forums/images/graemlins/crazy.gif
My set only went up to 1". /forums/images/graemlins/frown.gif
I'm putting together a list of the larger SAE and metric sockets I need and I'm going to ask for them for birthday presents. /forums/images/graemlins/grin.gif
~Rick
   / Socket sizes for B7500 HST??? #9
If you need to install a block heater you will need a 17mm allen wrench and ALOT of muscle. /forums/images/graemlins/tongue.gif
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2015 FREIGHTLINER CASCADIA (A50854)
2015 FREIGHTLINER...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
