So What Happened?
/ So What Happened? #11
I don't think having it in 4 wheel drive or the diff lock stuck would make any difference in ground speed. The only thing I can think of is a stuck break, or it change ranges. Does it have a low, med and high range? Did you bump it into med range?
/ So What Happened?
Just low and high.
/ So What Happened? #13
Coming from a paranoid person, I would look into it. I don't know about the B's but isn't there a throttle stop on the pedal? Maybe it came off? Air Pocket inthe hydraullics that worked its way out? (Ok, so this one might be reaching out there).
I agree 4WD/Diff lock wouldn't make a difference.
For the guys out there that really know there stuff, is it possible that pump starting pumping more fluid then it should? Some valve go bad?
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
2020 John Deere 8230R (A60462)
2020 John Deere...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
Bush Hog RDTH84 (A60462)
Bush Hog RDTH84...
Atlas HA-ECGO 3pt 5' Box Blade (A60462)
Atlas HA-ECGO 3pt...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
