So little 320dtc info 320 DTC Farmtrac
   / So little 320dtc info 320 DTC Farmtrac #1
brokeasajoke
320dtc
I inherited a farmtrac LG 320dtc and can find so little info on them on the net. Not sure if this is the correct forum, but looking for any info I can at all. I have no owner s manual so anything would help especially fluid specs. I can tell the clutch is only about 50hr old after being replaced at 300ish. Came with 5ft bush hog and a box blade but no FEL.:( Thanks all.
Thanks thats a start.
Here we go, this is what I know so far and I'm going to assume this applies to the 270 dtc as well as the 320 dtc.
Main gearshift gear selector lever on right side controls 4 gears which ARE fully synchronized but later in the book it says they are not. What the hay? Either it is or it isn't. I don't know.
For/Rev shuttle lever " although the tractor does not have to be stopped completely to reverse the direction of travel, we recommend that you stop, depress the clutch and then shift the shuttle lever for safety"
Speedometer shows speed in highest gear possible.
From experience, bleeding fuel air sucks. I had to bleed air from filter all the way to the injectors. Only bleeding 2 of them got me going.
Glow plugs. Warm weather 10sec Cold weather 20sec " When starting in cold weather, cover the radiator with a suitable object do the coolant can quickly reach a warm temp then remove the cover"
"DO NOT TOW TRACTOR. TOWING CAN CAUSE GEAR BOX TO SEIZE"
Differential lock is supposed to release upon pressing brake. Mine however does not.
PTO says it is dual disc but I only remember 1 disk 15years ago when we split it to change it. I've slept since then.
Cooling system 5.5qts of permanent type antifreeze but I use pretreated diesel antifreeze.
Fuel 7.4 gal
Engine oil 4.75qts of 15w-40 SF, CD rated
Transmission hydraulic oil. 9gal of Citgo tractor hydraulic fluid.
Grease multipurpose
Front axle oil. SAE 90 or equivalent.
320dtc 320 dtc 270dtc 270 dtc
Maintenance and service intervals
Done the 400 hr trans fluid change today. The spec is purtty close on 9gal. I used TSC premium trans/hyd fluid and a wix 51536 filter.
2014 DITCH WITCH RT45 (INOPERABLE) (A58214)
2014 DITCH WITCH...
2023 KOMATSU PC55MR-5 EXCAVATOR (A52707)
2023 KOMATSU...
UNUSED FUTURE 10' SLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 10'...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
