So I fired up my DK 45 at 0 degrees F today
   / So I fired up my DK 45 at 0 degrees F today #31
It's currently -22 C and I had to unexpectedly use the tractor, so it wasn't plugged in. It was NOOOOTTTT happy about it one bit. It took 3 cycles of the glow plugs to get it running and then it didn't sound happy at all. I'm guessing this is as cold as I've started it without plugging it in first. I ran the pto at idle and within 15 minutes, the engine temp was in the normal operating range.
   / So I fired up my DK 45 at 0 degrees F today #32
-40F? you must be stating wind chill temp?
I have always thought the worst thing you can do with a motor is start it when it is under 10 degree. You put more ware on it just starting it than many hours of operation.. Any opinion on this ?
   / So I fired up my DK 45 at 0 degrees F today #33
Had to run out to home depot right after I made this post. The car showed -29C. That would be why the tractor was so cranky.
   / So I fired up my DK 45 at 0 degrees F today #34
I get cranky well before -29 myself:D , Seriously though I plugged my block heater in about 2.5 hours before starting my white version of a DK35 at 2ºF and the glow plugs didn't even come on when I turned the key. The block heater warmed it up enough for a smooth easy start. I wouldn't want to start it any other way in these temps.
   / So I fired up my DK 45 at 0 degrees F today #35
has not been above 15 here for over a week. If you start them and let them idle until the oil gets a little warm I see no problems from doing that for 30+ years. If you have the correct grade of oil for the temps you should have no problems. If you start something and rev the crap out of it you will scuff the pistons at a minimum, I know I have fixed that a few times from disgruntled employees. CJ
   / So I fired up my DK 45 at 0 degrees F today #36
Easy fix: don't live there! :cool2:
But seriously, folks.....I concur - I would always try to plug in a block heater an hour or two prior to cold start attempt whenever possible. Synthetic engine oil, fresh/charged/heated battery, blended/boosted fuel, all come with living up here.
Then again, I have a heated pole barn. :p
   / So I fired up my DK 45 at 0 degrees F today #37
im located in Saint-Jean-de-Matha in Quebec, Canada... we had -33 celsius couples of days since last week, when I posted -40F...my truck was giving me that number so I figured it was -40 F/C (-40 seem to be the same in F or in C!)
the tractor dont like it for 5 mins after the start but hey, its the same for cars and everything around here. the Diesel want to freeze/gel, I always fill a 55 gallons and add anti-freeze additive for diesel into it.
plugging the block heater is easier on the mechanic of course, but sometime, you need the tractor to work ASAP. never had a problem with any machinery doing what im doing. I think you guys are too gentle with your engines ;)
   / So I fired up my DK 45 at 0 degrees F today #38
The cool thing about -40 is that it's the one temperature you don't need to specify C or F.;)
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
